Tip & How-To about Heating & Cooling
Carpet cleaning tips
Hence, here are a few tips, which are useful for carpet cleaning Bayside in an easier and smarter way, that can be done in few minutes.
Blot the stains
When something spills over on the carpet, the first thing most of us do is take a cloth and rub it, which is a wrong method of cleaning as the stains will only spread along and might be difficult to clean later. Blot the stains immediately with a sponge, clean cloth or paper towels and let it absorb without spreading it.
Shaving cream to remove stains
All houses do have a shaving cream in their bathroom cabinets. Just apply a little cream for any kind of stain and let it soak for about 30 minutes. After half an hour, blot the shaving cream away with a white cloth. Clean the place with equal measures of vinegar and water in a sprayer and spraying it where the shaving cream was applied.
Freeze the sticky gums
The tasty chewing gums are good as long as it is in the mouth, but with a house full of children, can have the half chewed gums sticking here and there and is extremely difficult to clean if it sticks to the carpet. Sometimes it is also possible to come sticking to our footwear from the outside and then stick to the carpets. The best and easy way to remove these gums sticking to our carpet is by freezing the gums with ice cubes for about 30 minutes. Once it becomes hard, take it out with the help of a spoon.
Hydrogen peroxide for blood stains
Sometimes there is a possibility of carpets having blood stains during any minor accidents at home and it is usually hard to clean once the stain dries up with red marks all over the carpet. Using hydrogen peroxide to clean blood spots on carpets is one of the best solutions. Blot the stain with water initially and remove it as much as possible. Use hydrogen peroxide later to remove the remaining stains. Blood reacts with hydrogen peroxide immediately with foams as soon as it is applied. Clean it with a white cloth.
House Office Carpet Residential Commercial Cleaning Geelong Commercial...
Heating & Cooling Logo
What is the best way to clean a fresh blood stain from a wool carpet?
Cold water on a clean cloth, blot with damp cloth, then with dry cloth, repeat, repeat, repeat until you do not see any red coming out. If you have a carpet cleaner flush it with lots of cold water sucking it up with your carper cleaner or extractor. A good professional carpet cleaner can prevent your spot from becoming a stain. Often you can use enzyme cleaners to remove blood but NOT on wool carpets.
Apr 07, 2016 | Vacuums
What can I use to remove a stain of SOYSAUCE in a carpet?
Carpet
1. Mix one tablespoon of liquid hand dishwashing detergent with two cups of warm water.
2. Using a clean white cloth, sponge the stain with the detergent solution.
3. Blot until the liquid is absorbed.
4. If the stain remains, mix one tablespoon of ammonia (Caution: Never mix chlorine bleach and ammonia - the resulting fumes are hazardous) with 1/2 cup of water.
5. Sponge the stain with the ammonia solution.
6. Blot until the liquid is absorbed.
7. Sponge with cold water and blot dry.
Nov 21, 2014 | Heating & Cooling
Small tar spots on my boardshorts from sitting on the rocks at the beach
Place a folded paper towel underneath the spots. Spray Goo Gone on the spots until they are saturated. Then use another paper towel to blot as much as possible. DON'T RUB. It will only spread it. Just blot. Then spray more GG on and wait a few minutes then launder with hot water and Oxy Clean. That should remove the tar stains.
Sep 23, 2013 | Clothing
What is the best way to clean a carpet?
Vacuum the carpet. Dampen a cloth with the cleaner or stain remover you want to use. Lay the cloth on the carpet for an hour, and then blot the damp area with a dry white cloth. If the cloth is stained with carpet dyes, test another cleaning product until you find one that does not make the carpet sample bleed.
Jun 11, 2012 | Vacuums
carpet stained
Ok in the future try to have carpet cleaned only by a pro. For spot cleaning use white paper towels or dish towels and warm water. (ONLY WHITE) 99% of fabric is white and then dyed to color and if you use a color cloth you might pull the dye from the cloth into the carpet. Now what you can try is your basic dishwashing detergent like electrosal with warm water and a dishtowel. little at a time try to blot not rub. try AFTA if that doesnt work. wet the rag first with warm water. pour the afta on the wet rag not on the carpet.
Jun 10, 2008 | Bissell OxyKIC - Oxygen Activated Carpet...
627 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
