Tip & How-To about Apple Macbook Pro 13 - Brushed Titanium - Back Bottom / 13 - Inch Silver Unibody 2009-2012
MacBook Pro Display housing coming off
If you don't want to spend a lot fixing your old macbook, this is an easy way to do it!
I hope it can help you.
keywords
MacBook Pro Display housing coming off fix
MacBook Pro display housing partly unattached fix
Macbook pro screen separating from the case fix
MacBook Pro unibody housing fix
Macbook Pro screen separation problem fix
MacBook Pro screen glass coming off fix
Broken MacBook Pro hinge fix
Apple Macbook Pro 13 - Brushed Titanium - Back Bottom / 13 - Inch Silver Unibody 2009-2012 Logo
why is my apple mac pro is very slow
There are a lot of possible reasons can cause a MacBook Pro to start running slow, generally related to hardware and software issues.
Check out this site http://www.macbookproslow.com/ for the top causes and quick step by step fixes.
Hope it helps!
May 18, 2014 | Apple MacBook Pro Notebook
macbook heats up a lot
A frequent cause of over heating is blocked air vents or a clogged fan. Use vacuum cleaner nozzle not too close to air vents and try and suck out surplus dust. Obviously don\'t then use it flat on your lap or bed, air needs to get to it all round!
Feb 07, 2014 | Apple MacBook Pro Laptop Computer with...
coins in macbook cd slot
This happened to me yesterday. My 3-year-old stuffed the Macbook's DVD/CD slot full of game tokens, hoping that one of them would play a movie. Took me his entire naptime to extract them, but everything works fine now.
First, open the guts of your laptop and remove the optical drive. Depending on your model the appropriate guide should be here:
www.ifixit.com/Guide/search/macbook+optical+drive+replacement
Among those I found the following excellent guide for mine:
http://www.ifixit.com/Guide/MacBook+Core+2+Duo+Optical+Drive+Replacement/518/4
Once the drive is out you can skip most of the remaining (replacement) steps, since you're putting the same drive back in.
Now switch to the following guide to get foreign objects out:
http://www.ifixit.com/Guide/Optical+Drive+Disc+Removal+Technique/772/1
Jan 23, 2013 | Apple MacBook Mac Notebook
my macbook dropped ..now battery cord doesn't light up very much and flickers... alot..? Is this an easy fix? Or is this gonna cost some bucks..? What could dropping the macbook have done to it
macbooks are very expensive to fix if you take them to the so called genie bar. so try a mall store to fix it or if money i no problem take it to the apple store.
Jan 15, 2013 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a Macbook Pro late 2011. 2.4ghz 4 gigs of ram 500gb hard drive. My computer wont fully start up. When it turns on it shows the apple logo the spinning wheel and loading bar. Then the bar goes away and then turns off. I know I need a new hard drive. But I don't have a back up of my computer. I was wondering if there was any way to back up the Macbook without getting it to fully boot up. Thanks.
Yes, there is a way to backup your Macbook .. but it will require you removing the hard-drive and using a SATA to USB adapter so you can retrieve the data from it.
Video on how to remove HDD:
http://www.youtube.com/watch?v=j1f7wotR_CQ
SATA to USB:
http://www.amazon.com/Vantec-CB-ISATAU2-Supports-2-5-Inch-5-25-Inch/dp/B000J01I1G/ref=sr_1_1?ie=UTF8&qid=1352310179&sr=8-1&keywords=sata+to+usb
Nov 06, 2012 | Computers & Internet
515 people viewed this tip
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
