Tip & How-To about Miscellaneous
Low oil pressure
If you notice low oil pressure, or oil warning light while your vehicle is running, shut down immediately to prevent costly internal engine damage, and have towed home or to a qualified technician to diagnose.
Troubleshoot Low Oil Pressure
http://www.autos.com/car-maintenance/low-oil-pressure-symptoms-causes-and-solutions
https://www.autohausaz.com/html/oil_pressure.html
Fixing Low Oil Pressure Light That On
Miscellaneous Logo
Where is the oil sending unit on a 1996 mercury cougar xr7 ? Its cause my oil pressure gauge is bouncing up and down...i dont know why...can anybody please help me thank you so much
The low oil pressure warning lamp will illuminate anytime the ignition switch is turned to the ON position without the engine running. When the engine is running, the light also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
If the oil pressure light does not work, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp lights, make sure the oil pressure switch is properly grounded in the cylinder block, and if so replace the oil pressure switch. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
To diagnose an oil pressure light that stays on, perform the following:
  1. Check the engine oil level and top off as necessary. If the engine was 2 or more quarts low on oil, test start the engine after topping off the oil level and recheck the oil pressure light operation. If the light stays on, stop the engine immediately and go to the next step.
  2. Disconnect the wire at the sending unit, then turn the ignition switch to theON position. If the light remains on, check the wire from the sending unit to the gauge for being shorted to ground and repair as necessary. If the light goes out, turn the ignition switch OFF and go to the next step.
  3. Replace the oil pressure sending switch with a known good switch.
  4. Start the engine and check the oil pressure light operation. If the light stays on with the engine running, stop the engine immediately to avoid severe engine damage until the cause of the problem can be determined.
WARNING
If the oil pressure light remains on while the engine is started, stop the engine immediately. Do not operate the engine until the cause of the problem can be determined. Operating an engine with low oil pressure will cause severe internal damage.
Possible causes for an oil pressure light to stay on are:
Pinched or grounded sensor wireDefective oil pressure sending unitRestricted or severely leaking oil filterExcessive internal engine bearing clearance.Insufficient or severely contaminated engine oilBlocked oil pump pickup screen or severely worn oil pump
Mar 31, 2016 | Mercury Cars & Trucks
Would low oil level cause engine to shut off while driving?
An effect of low oil level may damage valve lifters, they may have experienced excessive wear.
Definitively, continuous running of motor with low pressure might damage the motor.
If you check always oil level and it is an ocasional event, as long as the engine wasn't starving for oil under load (i.e. the oil pressure warning light did not come on), it won't have suffered immediate, catastrophic damage
I would worry more about the cumulative effect of chronic neglect. After the car is fully warmed up and warning light come on at idle your engine is on its last legs.
Sep 09, 2015 | Cars & Trucks
Light
This is the "Low Oil Pressure Warning" light. It is RED for a reason! When this light (or any RED warning light for that matter) comes on, pull over and shut the engine OFF at once. Allowing the engine to run with insufficient oil pressure can cause a catastrophic failure in mere seconds. Such a failure can cost thousands of dollars to repair.
This warning is most often the result of a very low oil level as indicated when checking on the oil dipstick. The engine oil level should be maintained as close to the "full" mark as possible - without exceeding it. Oil should never be allowed to drop below the "low" mark on the dipstick. If the oil level is shown to be between full and low, the light is probably coming on as a result of a faulty oil pump (the oil level should be checked with the vehicle parked on level ground, with the engine OFF). A faulty oil pump is unable to pump the oil with enough pressure to reach all the moving parts of the engine that require lubrication. Without proper lubrication, connected moving parts heat up, expand and seize. Moving parts are expected to move - not be prevented from moving.
If your engine shut down, it may be the result of some of the internal parts seizing. Hopefully, this is not the case. Check the oil level and top off as needed to bring the level up and attempt to start the engine and have the vehicle checked by a trusted mechanic.
May 17, 2013 | Cars & Trucks
2000 Mitsubishi eclipse the oil light came on and my car shut down. I added 1 quart of oil and it was full but the car still won't start.
The oil light does not indicate the car is low on oil (based on your discription) it indicates the oil pressure is low, the no start is most likely due to this low pressure and the fuel pump has been cut off to prevent damage to the engine from low oil pressure. Please have a shop locate the cause of the low oil pressure warning and repair it as needed. It could be a false light or a real one, which means if you drove it very far you may have damaged the engines bearings.
Sep 24, 2012 | Cars & Trucks
engine keeps shutting down
Most Honda engines have an oil pressure switch that prevents engine damage due to low/no oil pressure. Make sure there is sufficient oil in the engine and that the wire is connected to the pressure switch.
May 28, 2009 | Karcher 2500 PSI Pressure Washer
98 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
