Tip & How-To about Philips 37MF321D 37 in. LCD Television
Power Light Blink
I had a Magnavox 37MF321D that would blink the power light and the screen would flash but it would not power on or off. I show in the video below how I found IC 7003 bad and how to change it. I also show how I got a vertical line problem fixed. Below I added a link for the IC 7003 I ordered from Mouser Electronics. L5973D STMicroelectronics Mouser
Philips 37MF321D 37 in. LCD Television Logo
Magnavox 37MF321D/37 screen flashes with no pic, power light steady, capacitors in power supply look to be fine
I just fixed a similar problem on mine but the power light was flashing at the same time the screen was flashing. I made a video showing what part and how to replace it. I also added a link to the part I ordered. L5973D STMicroelectronics Mouser
May 22, 2012 | Philips 37MF321D 37 in. LCD Television
I have a magnavox 37MF321D/37 and the power wont stay on, just flashes. Replaced the IR sensor, still same thing.
Just fixed that exact problem on mine. I made a video on how I found the bad part and how to replace it. I also added a link to the replacement part below. L5973D STMicroelectronics Mouser
Oct 10, 2011 | Philips Magnavox 42MF521D/37 Television
My magnavox 37MF321D/37 will not turn on. It
I had the same problem with the blinking green light. These are the parts one the power supply I replace to repair it. note: If the power supply is repaired you will get a solid green light and the backlight will light up almost immediately.
Aug 01, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
1,079 people viewed this tip
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
