Tip & How-To about Computers & Internet
Computer unable to power on
If it is a case that you have recently use your computer and then the next day/hour your computer is not able to power on or there is no power. simple unplug power cable and any other devices/cables if connected. Then hold power button down for 30 seconds -1 minute.After holding power button down, release and try powering on normally.
Computers & Internet Logo
sony lcd tv model kdl-46EX711 one hour work good after stop start but no start red light [7] time blik next day start one hour why whats rong?
HI,
Probably the power supply have some faults. Mainly due to the dry filter capacitors. if you can replace the electrolytic capacitors in power supply board. Hope it will workout.
http://electro-medical.blogspot.in/
Apr 29, 2015 | Sony Televison & Video
Login Failed (#0001).
Hmm that very simple for solve it. The way you should not online facebook for 24 hours. Do not open before 24 hours from last zyngapoker case of error. Such as you are logged on at 07:00 pm, you must open it again at about 8:00 am the next day.
Best Regards,
Dona Alfian
Nov 01, 2011 | Facebook Social Network
only one of my UST-MS30 computer speakers is working...the right one is dead
Hi there!, I have read the manual for your system,..and maybe I can offer some solutions....Firstly, I am a musician and have experience with a lot of musical and studio equipment....some may seem simple, but it can bug you for hours or even days.
You must follow some simple troubleshooting steps,...to cancel out the possibilities.
Firstly, turn off your system, and disconnect it from the source,....I am guessing it is a PC.
Disconnect ALL connections and then set them up again with the power off. When all speakers and power supply is re-connected, turn on again. Run a speaker check, your system or PC should be able to help you with this. If the speaker is still not working, next, swap the right and left speaker outputs. If the speaker works, then the problem is NOT the speaker ok. If the speaker still does not work, then it is a bad speaker or bad lead to the speaker understand!?
Dec 13, 2010 | Yamaha YST-MS30 Computer Speakers
The monitor was working one day and the next day, it would not come on, screen black. My grandson has had the monitor for almost three years.
I'll hope for the best and assume the simple fix first. Check the plug at the back of the monitor to insure it wasn't pulled out slightly. Sometimes, moving something around can cuse the plug to lose proper connection.
Also, check the power source to insure that you have power to the unit. We had a lightening storm recently and the power strip surge protector did it's job. I turned it back on and everything powered up again.
I hope this helps... Good luck!
Sep 02, 2009 | Computers & Internet
Won't power up
I fixed it! Instead of 20 minutes I unplugged it for about 4 hours and everything is working fine. It's a moody ol' girl.
Mar 02, 2008 | Canon PIXMA MP830 All-In-One InkJet...
470 people viewed this tip
David Payne
David Payne
