Tip & How-To about Vehicle Parts & Accessories
Important info about posting vehicle issues
When posting issues or malfunctions about any vehicle it is very important to include the year make and model. Also, When you have MIL (malfunction indicator lights) on your dash, ex. check engine, abs, trac (!) etc it helps us to help you that much better if you get the vehicle scanned by a certified mechanic. Advanced auto, autozone or O' reillys will scan only ENGINE codes for free, the cannot scan any other brake, body or security codes so we recommend you take it to a reputable certified mechanic to scan these codes. Or you can purchase a scanner to do the job for around $60 to $75 and you can use this tool over and over again
Vehicle Parts & Accessories Logo
i went to scan my toyota yaris car and the following codes were give ; temperature ckt low input po117
EOBD II Error Code: P0117
Fault Location:
Engine Coolant Temperature (ECT) Sensor (G62) - Low Input
Possible Cause:
Malfunction Indicator Lamp (MIL) Triggered on first occurrence.
Coolant thermostat.
Wiring short to earth.
Engine coolant temperature (ECT) sensor.
EOBD II Error Code: P0340
Fault Location:
Camshaft Position (CMP) Sensor A (G40), Bank 1 - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) active.
Wiring from/to Camshaft Position Sensor (CMP) faulty.
Camshaft position (CMP) sensor faulty.
Timing misaligned.
Possible Solutions:
Check Wiring from/to Camshaft Position Sensor.
Check Camshaft Position Sensor.
Check Timing.
EOBD II Error Code: P0500
Fault Location:
Vehicle Speed Sensor (VSS) - Circuit Malfunction
Possible Cause:
Malfunction Indicator Lamp (MIL) Non Emission Fault - No warning light.
Wiring.
Vehicle speed sensor (VSS).
Engine control module (ECM).
Dec 13, 2012 | 2001 Toyota Yaris
What is mil control system
MIL stands for "Malfunction indicator light" better known as the check engine light or CEL. Please post make, model and year whenever using the site to ask a question.
Sep 28, 2012 | Cars & Trucks
Started having issues last 2 week where the fuel gauge would just die and then come back on. Yesterday, the check engine light came on and I testerd the computer mod which gave out code of P0442.
P0442 = Evaporative Emission System-Leak detected (small leak)
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, campaigns, illustrations and procedures, etc.
When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction.
SINCE I don't know which model/year (M/Y) Hyundai vehicle you have, it's difficult to help.
Sep 08, 2011 | Hyundai Santa Fe Cars & Trucks
What does it mean if the malfunction light on a 2001 Dodge Neon remains lite when engine is running?
Where have you been since 1980,some 32 model years?
The MIL Lamp,Check Light or any dash light
is an OBD2 (On-Board-Diagnostic) light indicating
a possible vehicle system malfunction
Check for codes --- within a couple of days
Diagnose system--soon
Repair or stop using the vehicle, if repairs can
not be made in a week or so
Jul 23, 2011 | 2001 Dodge Neon
Scanner shows P1451-- EVAP Control System Canister Vent Solenoid Circuit Malfunction.Solenoid resistance 34 Ohms.Wiring OK.No problem with engine.After erasing code P1451 appear again.What I must to do?Thanks in advance.
it is important to also include you make, model and year with this information, ford has made different types of evap systems over the years, each with different guided dignosis and each with different resistance values as specifications.
they have also published TSB's for specific vehicles for diagnisos aid
please re post the question with all information, and i will look for it, and aasist you on this topic
as first reply, after this i can not attach more than words, that why to re post and i caan attach vehicle specific diagnosis service publications
will watch for re post
have a nice day
Jay
Jun 07, 2011 | Ford Escape Cars & Trucks
787 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
