Tip & How-To about Miscellaneous
Traction on icy roads/hills
Good day,
Small tip...In a DESPERATE situation, you can release a small amount of air from your tires to improve traction on icy roads/hills. ****I would not recommend this action unless you are somewhere close to being able to add the proper PSI back into your tires. Incorrect tire pressure can have very negative affects on tires and handling ability****
Miscellaneous Logo
2003 Saturn ION What is the trac for and when activated, why doesn't it allow the car to go forward. When going up a icy hill, it will not allow me to go forward.
Traction control. It doesn't allow the wheels to spin. Chances are all the tires are on the ice and will not move because traction control won't let them spin and put you into a bad situation.
Mar 02, 2015 | Saturn Cars & Trucks
wat is the best gear to drive a nissan micra automatic in the snow
Choose 2nd that way the car will not coast to fast and it will also slow it down when your stopping but if its ice throw it into reverse so it will help stop
Nov 30, 2010 | Nissan Sentra Cars & Trucks
olds intrigue warning lights on...
It is a sign that you either have a bad wheel bearing or 1 off your speed censors on 1 of the tires is bad, I just had this problem with my olds alero, but it was a wheel bearing that needed replaced.
Jan 24, 2010 | 2001 Oldsmobile Intrigue
Toyota 2008 Highlander Hybrid Tires are TREACHOROUS!
A small amount of tire glue is apply on the rim of the tire during mounting.
The tire glue is to ensure there is a good seal and easy mount (when the metal bar slide the tire into the rim).
Air can leak from the tire valve or the rim.
I would use soapy water to check the valve and valve stem for air leak.
It may be too small to detect.
The quick fix is change the valve stem..
Dismount and remount WITH TIRE GLUE at a REAL tire shop will be final corrective measurement.
If you DO NOT go off road and want get a small mileage increase then you can use a smaller tire and rim package.
245-65-17 tires will save a little on your wallet.
2" decrease in diameter reduce the weight and rolling resistance.
The ride feel will be different.
Do a little checking with your local tire shop before you switch.
Good luck.
Jul 19, 2009 | 2008 Toyota Highlander
89 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
