Tip & How-To about ASUS Google Nexus 7 Tablet
Replace LCD and Touch Screen Assembly
Made a video on how I changed the LCD and Touch Screen Assembly on a 1st Generation 2012 ASUS Nexus 7. I also show why it's almost impossible to replace only the Touch Screen and had to replace the LCD and Touch Screen Assembly.
ASUS Google Nexus 7 Tablet Logo
my asus screen keeps flickering
I would open the back cover with a flat metal opening tool like this: http://www.ebay.com/itm/Tech-Metal-Spudger-Opening-Tool-for-ASUS-Nexus-7-1st-2nd-Gen-ME370T-ME571K-NEW-/161561753109?ssPageName=STRK:MESE:IT
then disconnect the battery 1st before anything. Check the LCD cable which is silver and runs from the MB to the LCD top to bottom over the battery. It looks kind of like a stick of gum. They often become loose and just need to be reconnected and secured better with some electrical tape. Be careful with the clips. I'm almost certain that is where your problem is and you should be able to fix it without much trouble.
Good luck
Apr 20, 2016 | ASUS MeMO Pad 10 ME102A-A1-GR 10.1" 16 GB...
How can I download flash player ?
  • Google is your friend in such cases :>)
  • How to Install Flash on the Nexus 7 and Other Jelly Bean ... www.howtogeek.com/120277/how-to-install-flash-on-the-nexus-7-and... 2012-07-29 · ... you can install Flash on your Nexus 7, ... it works flawless on Nexus 7. Thanks. ... Took the Flash Player 11.1 from my Galaxy Nexus and it works a ...
  • How to install Adobe Flash Player on Nexus 7 and Nexus 10 ... best-tablet-converter.com/.../install-adobe-flash-player-on-nexus-7-10 This tutorial will show you how to Download and Install Adobe Flash Player 11.1 on Google Nexus 7 and Nexus ... you can install Flash Player on your Nexus 7/10, ...
  • How to Install Flash Player on Your Nexus 7 Tablet to ... nexus7.wonderhowto.com/how-to/install-flash-player-your-nexus-7... Video embedded · There's no Flash Player or Flash plugin in the Google Play Store anymore, ... How to Install Adobe Flash Player on Your Nexus 7 Running Android ...
  • Nov 26, 2015 | ASUS Google Nexus 7
    how to put in sim card
    Assuming you mean the 2013 version but I'll try both,
    so for the 2013 version
    1. Turn your tablet off and place it on a flat surface with the screen facing up.
    2. Tilt the right side slightly up to find the SIM card tray near the bottom right and the small hole in the tray door.
    3. Insert a paperclip into the hole in the tray door, and push firmly but gently, the tray should pop out.
    4. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271601_en_v0Remove the tray and place the micro SIM card inside it, the angle corner fits with the angled indent
    5. Push the tray it gently back into the tablet.
    6. snp_8a30b60eaed5a3a37f46a8c715167552992e_3271604_en_v0
    Activate SIM card
    1. Open the Settings app snp_2918920_en_v1 and turn off Wi-Fi after completing the set-up instructions. Once Wi-Fi is off, you'll see a notification at the top of your screen.
    2. Swipe down the notification shade and touch the notification.
    3. Follow the activation instructions provided by your carrier.
    For the Nexus 7 (2012) 3G use the same process noting that the tray slot and pinhole is on the left side of the device when its facing up.
    *Note* : Only the Nexus 7 (2013) LTE & Nexus 7 (2012) 3G can accept a SIM card. Wi-Fi versions of the tablet can't.
    Dec 10, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
    1,178 people viewed this tip
    Top ASUS Tablets & eReaders Experts
    Alun Cox
    k24674
    Are you an ASUS Tablet and eReader Expert? Answer questions, earn points and help others
