Tip & How-To about Home
How to clean the glass on a woodburner
Here is an easy way to clean the glass on a word burner
Home Logo
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
Had a spill on my kitchenaid KGCC566RBL gas glass cooktop. some dripped in the knobs and under the glass top. How do I access that to clean?
I found this......
https://www.doityourself.com/stry/how-to-replace-a-glass-cooktop-on-kitchenaid-ranges
I read it and it's on replacing but the top comes out.
Gloves are a good idea too. Cut power at the breaker.
unless easy access to the wiring/plug.
Hope this helps you.
Have a good evening.
Feb 02, 2018 | KitchenAid KGCC566RBL - 5 Burners...
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
the glass top on one burner has discolored under the glass as if it is burned under the glass. nothing will clean it. what do I do to get the black out
if under glass it will have to be removed to clean/ it might not clean. . the replacement is only other ans . mm
Dec 06, 2009 | Refrigerators
357 people viewed this tip
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
