Tip & How-To about Dewalt Tools & Hardware - Others
Modified stator field
Dw712 crosscut saw miter saw i have had a problem with the motor stator electric field and i was surprised by the MODIFICATION not seen if you don,t know about that this machine has undergone by the later builds of the same type .
Because the difference was not to find in the diagram and ordernumber of this stator field , because the older model has only 2 connecting wires,, and the later modified model has a stator field with 4 connecting wires . it has also a different ordernumber and is also a little bit more expensive.
So be warned when ordering a statorfield check the stator after 2 or 4 stator contacts advance order , it can has also be modified in the usa on the same way . !! i have also have asked for made changes on a diagram by Stanley/Dewalt (England) in between 1 hour they have made an change for it , for a powertool that was missing a type of [ model DC837 type 1] type 10 and 11 where the only ones to see there but type 1 was missing and the switch for that model was a problem but they have special made a kit for it because of the modified switch .
DW712 VERSTEKZAAGType 1
Tools & Hardware - Others Logo
what is a miter saw?
A miter saw (also spelled mitre) is a saw used to make accurate crosscuts and miters in a workpiece.
Jan 28, 2013 | Saws
where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
rebuild dw708
I assume you are asking about the Dewalt
DW708 TYPE 3 Crosscut Miter Sawas seen here
http://www.ereplacementparts.com/dewalt-dw708-type-crosscut-miter-saw-parts-c-1009_1163_2604.html
Have you taken it apart yet? You will need screwdrivers, spring clip pliers, small bearing puller and a pipe same diameter as the inside of the bearing; for replacement of bearing.
Be sure to take out the brushes before taking out the armature.
Part 165-90
You most likely will have to replace part 87 too.
The bearing rests in there and gets worn too.
Serious bearing/vibration problems causes the end cap part 84, to wear out.
Jan 23, 2012 | Cars & Trucks
how do you change the brushes
You have two, 1/2 inch flat head screw things on the right side of the motor, pull them out, the carbon should be at least 1/4 inch long, min, brushes can be bought at the hardware store. The electric brakes on those saws eat them brushes up. Check it out.
Jul 12, 2010 | Dewalt DW712 Factory Reconditioned Heavy...
My mitre saw won't power up. I moved it and it worked a few days ago. I have it plugged in. The electrical plug has power (checked with something else) but the saw won't turn on. Is there a reset somewhere or something else I did?
There may be a RED reset button on the motor, It won't push very far, Unplug the saw push the reset and try it again
You may have sustained some damage to the power cord and need to take a look at the internal cord connections
Apr 02, 2010 | Dewalt DW712 8 - 1/2" Sliding Compound...
344 people viewed this tip
Top Dewalt Tools & Hardware - Others Experts
John Trevino
Ruben Bustamante
Are you a Dewalt Tool and Hardware - Other Expert? Answer questions, earn points and help others
