Tip & How-To about Fuel Line & Primer Bulb Repair Kits 2 Cycle Fuel Line Repair Kit For Chainsaws Snow Blowers Weedeaters And For All Makes And Models Of 2 Cycle Equipment. Fits Poulan Craftsman Snapper Homelite Ryobi Idc Featherlite Robins Husquvarna Weedeater Mtd John Deere And More
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
Fuel Line & Primer Bulb Repair Kits 2 Cycle Fuel Line Repair Kit For Chainsaws Snow Blowers Weedeaters And For All Makes And Models Of 2 Cycle Equipment. Fits Poulan Craftsman Snapper Homelite Ryobi Idc Featherlite Robins Husquvarna Weedeater Mtd John Deere And More Logo
The fuel lines in my Ozito 25.4 cc 305mm bar chainsaw are perished, how do I replace them?
Chainsaw fuel lines are specialized hoses that either need to be replaced with TEFLON hoses of the same diameter, or the specialized rubber hoses that are resistant to gasoline and other chemicals. You should ask at a hardware store and make sure you get a hose that fits TIGHTLY into any holes on the gas tank, and also snugly fits over ant incoming metal or brass lines going into the carburetor.
Oct 18, 2014 | Garden
HOW DO YOU REPLACE FUEL LINES ON A CRAFTMAN CHAINSAW MODEL 358355160
The lines are usually a tight fit in the fuel tank. This prevents leaks. They must be pulled out of the tank (one at a time) then cut the new lines end in a "v" pattern, this will allow you to push the new line through the tank. Long needle nose pliers are needed too.
May 09, 2014 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
tppOn my Poulan Wild Thing 18" chain saw the fuel line appears to have out of the hole going to the gas tank. How do you get the line back through the hole, it is a very tight fit?
Cut the end of the hose off at a steep angle, push it into the hole in the tank, now use a pair of needle nose pliers through the fuel filler hole to grab the end and pull it through.
Feb 05, 2011 | Poulan 18" Wild Thing Chainsaw
how do you fix the plastic gas line? It doesn't stay in the gas tank. When I prime the bulb the gas squirts out and when the echo blower is in use, gas ends up leaking on my leg.
The holes in these gas tank are made to fit available fuel lines tightly enough to prevent the problems you are having. If yours is leaking either someone put on too small a fuel line or made the hole larger so it would be easier to put the fuel line in the tank. The only fix is to get the next size larger fuel line or replace the tank. You can try to seal the line with RTV or silicone but he gas will degrade it and it will leak again plus you'll have a harder time the next time the line has to be replaced.
Jan 05, 2011 | Echo Back Pack Blower Rack Fits Stihl...
Reattaching fuel line to gas tank.
Get a new line the same size and length of the old one. Get the filter out of the tank. If it is as I think, it has a barbed end that goes into the outlet hole. Take your new line, fit it onto the filter end and make sure it is all the way on. Take the other end of the line and cut a taper on the end. Thread the end through the tank, into the outlet hole and aissist it so your filter sticks through the tank hole. There was a ring on the outside of the tank, on the line. Take that ring and run the ring over the end of the tube up to the filter bottom. Make sure it goes all the way up to the bottom, and tight.Square off the end and slip it onto the carb...Good luck...Lee
Aug 27, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
563 people viewed this tip
Top Fuel Line & Primer Bulb Repair Kits Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Fuel Line & Primer Bulb Repair Kits Garden Expert? Answer questions, earn points and help others
