Tip & How-To about Kodak Office Equipment & Supplies
Reset memory on Ink supply for Kodak printers through computer maintenance
Communicating with computer
1 With printer on, remove cartridges.
2 Turn printer off for 5 sec's./then back on
3 Double click Kodak printer icon, go to maintenance
4 From the menu, select Ink level. It will warn there are no cartraiges. Press OK
(At this point the memory has been reset)
5 Replace your cartridges and power off printer again for 5 sec's./Turn back on.
ironically, this does NOT work on my Office Hero 6.1
on the Kodak ESP 5200 series what does a 3501 error mean? can it be fixed by a user? will new cartridges fix the problem?
Hi!
The 3501 error code means "acces door open"
Please be sure that the printer's acces door is well closed.
If this doesn't fix the problem, please do the following:
1. Turn the printer off by pressing the on/off button
2. Unplug the power cord
3. wait for 1 minute
4. plug the power cord back in
5. turn the printer on
Hope it helped.
Regards,
Bogdan
Aug 20, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
what does error code 3820 mean for a kodak esp5 all-in-one printer
The error message "Carriage Home detection failed" (error code 3820) can be resolved by following these steps:
To resolve this error:
1.Open the printer access door.
2.Disconnect the power adapter from the printer.
3.Gently hold both sides of the carriage, located immediately behind the print-head, and make sure the carriage moves freely.
•If the carriage does not move freely, contact Kodak.
4.Remove the print-head and ink cartridges.
5.Reinstall the print-head and ink cartridges, making sure each clicks into place.
6.Connect the power adapter to the printer.
7.Turn the printer on, if necessary.
8.Close the printer access door.
If the error continues, contact Kodak.
Sep 07, 2010 | Kodak Office Equipment & Supplies
Bypassing printer warning that stops my printer
this one is one of my favourite hate printers... but, no you cannot disabel this function easy, you can "fool" this printer by following that procedure:
1. switch off your printer, wait few sec, switch it on
2. on your computer go to "start"
3. select "control panel"
4. select "printer and faxes"
5. right click on your "kodak easyshare 5300"
6. select "properties"
7. click on tab "services"
8. select "service this device"
9. click on tab "estimated ink level" - it shows estimated ink level after restart
you can use refill (very easy to do by yourself and about 1/3 cost of original replacements). and yes, you are right, cartridges do tend to dry out. i would suggest printing at least one page per week to prevent dry out of the cartridge.
as this particular printer will not work without both cartridges present. i would suggest to insert one empty cartrdge in colour slot and keep it there. on full cartridge use any sticky tape to prevent nozzle from drying, cover breather hole on the top of cartridge as well. when you need to print, remove tape from breathing hole first and then from the nozzle. this way you will prevent or at least slow down your cartridge evaporation ratio.
Jul 28, 2010 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have an HP Photosmart Premium Printer Cd055a and it is connected to my wireless network. However, everytime I send something to the printer it says that the printer is offline. The wireless radio on the printer is working and my computers are hooked up to the same wireless network but the printer still says it's offline.
Check the IP addresses of your computer and Wireless Printer. It should be in same range. For Example if your PC is configured with static IP 192.168.1.1 then your printer IP address should be 192.168.1.x (First 3 octact must be same).
If IP addresses are in same range then try to PING Printer IP from Computer command promt in this way
ping 192.168.1.x (where x is Printer IP address) if reply is comming. then Goto start menu , Printer and faxes and double click priter and remove check mark "Printer is Offilne" Printer Menu.
Mar 11, 2010 | Office Equipment & Supplies
I have a kodak 5500 aio printer. I replaced the
Try the following:
1. Open the printer access door.
2. Put out both ink cartridges and the printhead.
3. Let the printer access door open.
4. Put out all paper.
5. Pull out the ac adapter at the back of the printer.
6. Wait 60 sec.
7. Pull in AC adapter.
8. Wait 30 sec. then turn on the printer
9: Wait for the error message: Printer access door open.
10. Close the printer access door.
11. Wait for the error message: Printhead is missing.
12. Open the access door and put in only the printhead and the close the access door.
13. Wait for the error message: both ink cartridges are missing.
14. Open access door, put in only the black ink cartridge, then close the acess door.
15. Wait for the error message: Color ink cartridge is missing.
16. Open access door, put in the color ink cartridge and then close the access door.
If the error is solved, do a firmwareupdate right now.
You can find it here.
Sep 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
1,292 people viewed this tip
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
