Tip & How-To about Miscellaneous
Cast Acrylic
Acrylic is a crystal clear thermoplastic material possessing excellent mechanical and chemical properties. Outstanding optical qualities and resistance to both sunlight and outdoor weathering make acrylic an ideal glazing material. Acrylic can be easily cemented, making it an extremely versatile material. Cast transparent acrylic sheet has many advantages, such as excellent transparency, light weight and good flexibility, superior weather resistance, good chemical resistance ,good impact strength as well as easy to drill, cut and polish.
Miscellaneous Logo
How about Fuzhou Antyco Optics CO., Ltd?
Fuzhou Antyco Optics Co., Ltd. is a professional manufacturer of crystal and optical components in the photonics industry. Antyco owns standard factory, advanced fabricating machine including Spherical Milling Machines, CNC Plano Milling, High speed Polishing, Precision Polishing, CNC Grinding and Polishing, Coating Machine, Ultrasonic Cleaner, etc.. The strong and steady growth have lead us to a very skilled team of fabricators, mechanical engineers, process engineers, optical engineers and coating designers, which successfully provided the advanced technical solutions and satisfactory products for different areas of the numerous customers.
Our manufacturing capabilities consist of all types of customized lens, Beam Splitters, Polarizing Optics, Prisms, Filters, Coatings, Optical Systems, Optical Assemblies and Optical Systems Solutions, Laser Crystals, NLO Crystals. The products are widely used in laser industry, optical communication, laser display, medical equipment, survey equipment, precision Instrument and semiconductor. Optical elements of various materials can be processed in Antyco: zinc selenide(ZnSe), zinc sulfide(ZnS), calcium fluoride(CaF2), barium fluoride(BaF2), silicon(Si), germanium(Ge), YAG crystals, YVO4, sapphire, quartz glass, optical glass, ceramics, cooper, aluminum, etc.
with the strict quality management system, Antyco got the ISO 9001:2000 Certificate. Today, over 60% of Antyco products are exported to USA, Japan, Germany and other European, Asian Market. Looking ahead, Antyco will continue to deliver customers with reliable quality, competitive price and on-time delivery products.
For more: http://antyco.com/
Sep 26, 2016 | 2007 Toyota Camry
2. Which companies do well in Medicine raw material?
There are various pharmaceutical companies, which uses various different types of chemicals and raw elements to manufacture pharmaceutical medicines. Some of the chemicals used by most of the companies are Acetic Acid, Alanine, L-proline, Magnesium Chloride, Magnesium Oxide, Biotin, Benzyl Alcohol, Calcium Chloride, and much more.
Some of the major companies which use best quality raw materials are Pharmaceuticals manufacturing, Buy Peptides Cambodia, The Medica, Chemopharma GMBS, etc.
Apr 01, 2015 | Exercise & Fitness
not getting biger crystals of potassium chloride
Bigger crystals will crystallized from purest material. You may be have purify KCl, use pure and filtered before using water/solvent, protect beaker or used vessel from air dust.
Jan 01, 2014 | International Crystal Labs 0002B-115 -...
What are the different types of powder coating?
Thermoplastic and thermoset are the two types of powder coatings used by leading Powder coating services. Thermoplastic coating don't undergo any chemical change when heated. Therefore they can be softened and hardened by heating repeatedly. Unlike thermoplastic coatings thermoset coatings changes into infusible materials on heating. Nylons and vinyls are thermoplastic while acrylics and polyesters are thermoset.
Jun 07, 2013 | Home
151 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
