Tip & How-To about Apple iPad Tablets & eReaders
How to unblock sites in iPad or iPhone
The most secure and reliable way to open blocked sites in iPad or iPhone is using vpn. You do not need any specific application for this. You can simple make a new vpn connection on your iOS device with standard iOS features.
All you need is setup vpn connection following simple steps below:
To make a new vpn connection in your iOS device you need to do the next:
  1. Go to Settings > General > VPN
  2. Click Add VPN Configuration
  3. Choose PPTP VPN and enter you VPN account data. You will receive your VPN server, username and password in the e-mail
    Server address must be exactly as in your account data (without http://, www or any other symbols)
  4. Save your VPN configuration. Once you have created VPN connection you can switch it ON and OFF on the main settings screen
Once you have created vpn connection you can switch it on and off on the main settings screen.
Under the vpn connection you can access any blocked website and be absolutely sure that you are safe and secure.
Sahrzad VPN How to Setup Guides
Tablets & eReaders Logo
I cannot down load films nor to shows onto my ipad
3 steps to download movies
1. Go to the iTunes application on your iPad.
Click on the little purple application with the musical note on it. The iTunes application should already be installed on your iPad. All you need for this method to work besides the application is a stable Internet connection.
2. Go to the iTunes store. Just select this option at the top of iTunes. This will allow you to find a movie to download onto your iPad.
3. Click "Movies." You can find this option on the top middle of the screen.
hope it work
Dec 20, 2016 | Tablets & eReaders
Retrieve lost contacts on my ipad
Do you have backups on iTunes or iCloud? If not, you may need a professional iPhone contact recovery program on your computer.
How to Recover Deleted or Lost Contacts from iPad
Sep 20, 2015 | Tablets & eReaders
My ipad has too much on it I need to clean unwanted programs and leftover bits from deleted programs
If you go into Settings > General > About. You should see all the information of your iPad. You will notice how many songs, videos, photos and applications etc.. you have. Also the capacity of the iPad (in terms of GB). Keep in mind, approximately 1-2GB of data is used by iOS7 (or whichever software update you have). Hope this helped!
Sep 02, 2014 | Apple iPad Tablets & eReaders
i cant get my yahoo mail because my i pad will not connect to my wifi
If your wi fi will not connect then you need to get that sorted before you are able to get your mail. To do this I suggest turning the iPad off and go and unplug your router - the one connected to your computer from the wall for 5-10 minutes. Go back and plug it back in and that will power cycle it. Once you have done this go back to the iPad - Tap Settings > then Network >tap the wifi button and slide to on > then select your network and you will need your password.
Once you have done all of that you should be able to connect.
Let me know how it goes.
For step by step video guides for the iPad covering all features head over to >> http://www.tabletmastered.com/blog/
Mar 13, 2013 | Apple iPad 32 GB WiFi Tablet PC
problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
Feb 11, 2010 | Apple iPad 64 GB WiFi
1,491 people viewed this tip
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
John mullen
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
