Tip & How-To about Miscellaneous
Sagging handle on Emtek door lock set
My front door has a very nice Emtek cast bronze door latch set with a deadbolt. a few months ago the inside handle started sagging so I looked on line and did not see what I thought the problem might be. At any rate it turned out to be super simple so I thought I would post the fix hear with pics.
I simply removed the interior side of the lock set and found that the spring that holds the lever handle up had slipped off its stop. I simply removed the lock washer that holds it in place, re positioned the spring behind the stop and it works great now.
I am not sure how the spring slipped off, as it is quite tight but I am sure it had something to do with two ten year old boys going in and out constantly ;-)
Miscellaneous Logo
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
Rear driver's door will not open from inside
The linkage from inner handle to latch release could be out of adjustmernt or some of the plastic clips have there threads ripped out. Do a test first. compare the amount of effort resistance felt on the good door
Dec 28, 2013 | 2006 Ford Fusion
how to remove gatehouse door knob?
Look for a small set screw on the side of the deadbolt on the inside of the door loosen the set scrww and remove the cover to expose the screws that hold the door knob on
Oct 31, 2013 | Gatehouse Springfield Satin Nickel...
i have deadbolt segal lock that was working for 2 months. suddenly today i can't lock the door from the inside. locking works from the outside. when i lock it from the outside i can unlock it from the inside but simply turning the key from the inside to lock the door is imposible. qwhat is wrong?
Sounds like the tumbling mechanism for the handle may be off......check to make sure that the screws are tight that lock the front and back of the deadbolt together. Make sure that the door is fully closed and check to see where the deadbolt is hitting the striker. It mat be as simple as the door and frame have expanded a bit and the door is not fully seated when you close the door from the inside. See if these help if not please contact me as I wish to find a solution to your problem.
Thx
Deathstalker
Aug 21, 2009 | Locks & Locksmithing
207 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
