Tip & How-To about Ovens
OVEN PRE-HEATING
This tip will help consumers get the best cooking performance out of their ovens, gas or electric. When an electronic controlled oven pre-heats, it has what the manufacturers call "the initial spike". That is, for the time until the unit beeps at you telling you it's at the proper temperature, most ovens heat up 50 degrees or more hotter than what the set temperature is. This extra temperature is to help the floor, walls, and ceiling of the oven reach the same temperature and stabilize, providing more even cooking. When the oven beeps at you, it has measured AIR TEMPERATURE, NOT THE TEMPS OF THE CAVITY AREAS. For **exposed element** models, normally, the consumer should wait approximately 10-15 minutes AFTER the beep is heard.
For **gas ovens**, the consumer should wait approximately 8-10 minutes after the beep before cooking anything.
For **hidden bake element models**, the consumer should wait approximately 20-25 minutes after the beep is heard to cook.
This is because the heat from the bake element must pass through the metal of the floor and heat up the oven cavity.
I hope this information clears up some confusion about oven operation!
Ovens Logo
Why won't my gas grill stay lit?
Oven clicks as if it is relighting almost constantly.
Old electric range ovens use a coil heating element called a resistive coil.
This is nothing more than an electrical wire encased in a sheath. They have flat black coils over rounded burner drip bowls that catch your drips and spills.
The newer glass-ceramic cook top style element produces heat that radiates through the glass top to the cookware above.
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
ELECTRIC OVENS:
CHECK THE OVEN RELAY CONTROL BOARD Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
Jul 04, 2014 | Zanussi Ovens
NATURAL GAS OVEN WONT COOK PROPERLY
· Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
· Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. GAS OVENS 1)The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
ELECTRIC OVENS:
Apr 06, 2014 | Frigidaire Ovens
ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
Pre-Heated my oven, it beeped and I put muffins in. They began to cook and suddenly oven lost heat. When I try to pre-heat now, it clicks as if it is pre-heating but I am getting no heat. I have checked fuses and replaced the temp sensor but still no heat. Anyone have any suggestions as to what the problem maybe. Thanks
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Asker's Testimonial " thanks i will have my husband look into that. " - 2gunsally
Aug 10, 2010 | Kenmore Ovens
555 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
