Tip & How-To about Samsung Dryers
SENSOR DRY IN SAMSUNG DRYERS
As a tech, I'm constantly fielding questions about loads of clothes not drying properly in the larger Samsung dryers--and this tip can be used for a lot of dryers with the sensor-dry feature. Sensor drying uses a pair of metal strips located on the filter holder or on the back wall in the dryer. When wet clothes rub against the strips, this sends a signal to the main board which tells the dryer to keep going. Unless large loads are used, the consumer should use "timed dry". This is because smaller loads won't hit the sensor strips often enough and cause the computer to count down too rapidly. Also, consumers should try to make sure like items are placed with like items( shirts with shirts, pants with pants, towels with towels, etc) Thick clothing(jeans, heavy sweatshirts, etc.) usually will have damp spots like pockets due to the moisture not being able to contact the sensor strips--the technology is not 100%. Also, if there are problems with the timer starting to count down too rapidly all the time, and dryer sheets are used, the sensor strips may be coated with a waxy layer. Use some super fine emory cloth to polish the coating off of the sensor strips. You very well might find that the problem is solved and not have to initiate a service call!
Dryers Logo
whirlpool duet gas dryer
The question is are your clothes getting dry? The flame does not stay on constantly, but cycles on and off. Now if the clothes aren't drying properly, then the first thing to check is if you have good air flow coming out of the back of the machine and air flow completely outside where the vent exhaust to. If that is good then most likely your flame sensor has gone bad and needs to be replaced.
Aug 25, 2012 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Dryer (model no. LGR4634EQO) is no longer heating, or getting hot at all. How can I troubleshoot it??
Hello.
suggestions about things they can do to troubleshoot commonproblems.
Instructions
    • 1 Open the dryer door and remove the lint screen ifthe clothes are not dry after a drying cycle completes. Remove the lint fromthe lint screen and replace the screen. The dryer ought to dry more efficientlyafter the lint screen is cleaned.
    • 2 Open your home's breaker box if the dryer is notturning on or no indicator lights are visible on the front panel. If theswitches for the dryer in the breaker box are flipped to "Off," flipthe switches over to the "On" position.
    • 3 Remove some of the clothing in the dryer or drysmaller loads if you notice that the clothing is wrinkled when you finishdrying a load. Larger loads cause the clothing to wrap around one another whendrying, increasing the likelihood of wrinkles.
    • 4
Pull the dryer unit away from the wall and checkon the position and arrangement of the exhaust vent. An exhaust vent that ispinched between the wall and the appliance or an exhaust vent that is kinkedcan't allow air to flow through it properly, making it difficult for theappliance to dry properly.
    • 5
Make sure the door is closed if the dryerdoes notrun. Also check to make sure that you hold in the "Start" button forat least a second. Pressing the button for less than a second may not give thethe dryer enough time to recognize the button has been pressed and that itshould start.
Thanks for using fixya.
Jul 31, 2011 | Dryers
Clothes not dry. Take about 3 hours to dry the medium load of regular clothes.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101'
Jul 18, 2011 | LG Dryers
WON'T DRY CLOTHS..NO HOT AIR
heatman101;'';';
Jun 27, 2011 | GE Dryers
Samsung electric dryer model # DV328AEW not heating up to dry clothes
heatman101.,//';
Mar 09, 2011 | Samsung DV448AEE Electric Dryer
1,359 people viewed this tip
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
