Tip & How-To about Kitchen Ranges
Replacement of Whirlpool part 77001257 by 8203529 for Amana ARTC8600WW range (year 1999)
Control switch for dual heating surface element in our Amana ARTC8600WW range (year 1999) failed and did not cycle power after the heating element was turned on. The range was in very good condition so we wanted to replace the switch. However, the original Amana part Y0315855 was not available. The company was taken over by Whirlpool and we found that Whirlpool part 77001257 should be used. But that part was not produced anymore either. On Best Buy web site we found information about an alternative 8203529 Whirlpool part. We order it, installed into the range, and got no action. From other web sites we quickly learned that the part is not the right replacement and that there is no replacement switch for our range at all. We hesitated to replace entire range so instead of returning the part to Best Buy we decided to investigate the differences between the original part and 8203529. Soon we began to believe that 8203529 should work. Specification as well as all connections were fine so we tried to adjust a little bit the tension of bimetallic element inside the switch. There is a tiny screw accessible for this purpose. The adjustment can be done be a 5/64 hex key which, for electrical safety, we insulated by a plastic tube. Immediately we got the expected action. We tested all settings before mechanical installation and all of them worked very well. The mechanical installation of the switch needed a makeshift bracket to distance the switch from the back of the panel wall in order to get the position of the switch knob properly leveled with the front wall of the panel. Just shortening the shaft of the switch was not sufficient. The bracket that comes with 8203529 was not suitable for our range. It was not difficult to make another bracket so we repaired the range without compromising its functionality or safety. That confirms that part 8203529 can be used in place of Whirlpool part 77001257.
Kitchen Ranges Logo
I have a Jenn-Air JES9900 range and the right front burner is not working but the hot indicator light remains on. Is this just a switch that needs to be replaced?
make this test and fix it. God bless you
Surface Element Switch
If the surface element won't work, and there is another element of the same size on the stove, try switching the elements. If it still won't work, the surface element switch is probably defective. The surface element switch can't be tested or repaired, it will have to be replaced.
Enter your model number to see parts for your range/stove/oven.
Help me find my model number
Surface Element Board
If a surface element won't work the surface element board might be defective. Each burner is switched on and off with the help of a relay on the surface element board. If one or more relays has failed the surface element won't work. If two or more burners fail at the same time, this is likely the problem. If only one surface element won't work and the element itself checks out to be good, the surface element board might be defective.
Coil Surface Element
If the surface element won't work, the coil surface element might be burned out. Most coil surface elements can be pulled out of their socket and checked with an Ohm meter for continuity. If the surface element won't work, check to see if there is any visible damage to the coils. Also, check to be sure the element is pushed all the way into the socket.
Radiant Surface Element
The most common cause when the surface element won't work is the radiant surface element itself. The radiant surface element - or heating element - can burn out similar to a light bulb. If the surface element won't work and it doesn't have continuity, it will need to be replaced. The radiant surface element is not repairable.
Solid Surface Element
If the surface element won't work, and the stove has the solid surface element type of heat, it's likely that the solid surface element itself has burned out. The solid surface element works very similarly to other surface elements - inside there is a heating element that glows when electricity is applied to it. As it gets hotter, the heat is transferred to the solid surface element
Element Receptacle and Wire Kit
If a surface element won't work, there may be a problem in the element receptacle. The surface element plugs onto a terminal block type receptacle. Over time the terminals in the receptacle can have a bad connection and overheat. Look at the receptacle contacts with a flashlight. If the terminals look burnt you will need to replace the element receptacle. also make sure the element prongs are clean and not burnt. If the prongs are burnt bad the element will need to be replaced also.
Loose or Burnt Wire Connection
If surface element won't work, there might be a burnt wire supplying power to the surface element. Sometimes the wire supplying power to the element burns out right near the element itself. Check for this by just looking at the wires leading to the element. If they're burned out it is usually easy to spot.
Incoming Power Problem
Although not as common, if the surface element won't work it is possible that the appliance is not receiving proper voltage. Electric ranges require 220 volts of alternating current. If for some reason the appliance is receiving significantly less, the surface element won't work. Check for proper voltage using a volt meter at the socket where the appliance plugs in.
Nov 04, 2013 | Kitchen Ranges
Could this be a User Interface,Board 316239500 part problem? or a Electronic Control Board part problem?
Normally, the E.O.C. (electronic oven control) only controls power the ehe bake/broil side for the oven. Doesn't control power to the element. If you have already replaced the infinite switch to that eye, the element itself could be faulty. There is a sensor inside the element that is supposed to communicate with the infinite switch to determine the proper cycling temp for what you selected.
Jan 31, 2013 | Frigidaire GLEF396 Electric Kitchen Range
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be the heating element. What further review can we do at home to diagnosis the problem and do you feel the problem is the heating element?
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
0ne of the surface units does not heat. Frigidaire Electric Range
HI, You will need to change the burner switch. When the element shorted, it took out the switch also. If you need help with part#, please let me know
Thanks
Vic
May 17, 2009 | Kitchen Ranges
Hot surface indicator
The component that controls the hot surface light is part of the element. If there is a light for each element you just replace that element. If there's one for the whole surface or each side you'll have to figure out which element is causing the problem.
Oct 27, 2007 | Maytag MER6772 Gemini Electric Kitchen...
1,159 people viewed this tip
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
