Tip & How-To about Air Conditioning and Heat for Chevrolet HHR Panel LT New Cars
Overheating of car
HII,
NOTE: To avoid burns and injury, never, ever attempt to remove a radiator cap while the engine is hot!
An overheated engine can be caused by anything that decreases the cooling system's ability to absorb, transport and dissipate heat; therefore engines can overheat for a variety of reasons. Let's take a look at some of the most common causes.Cooling System LeaksThis is the primary cause of engine overheating. Possible leak points include hoses, the radiator, water pump, thermostat housing, heater core, head gasket, freeze plugs, automatic transmission oil cooler, cylinder heads and block. Perform a pressure test. A leak-free system should hold pressure for at least one minute.Wrong Coolant ConcentrationBe sure to use the coolant recommended by your vehicle's manufacturer. The wrong type of coolant and/or mixing the incorrect concentration of coolant and distilled water can also result in engine overheating. The best bet is to perform a complete flush and fill.Bad ThermostatA thermostat is a heat-sensitive valve that opens and closes in response to engine temperature. Heated engine coolant passes through to the radiator when the thermostat is in the open position. In the closed position, it prevents the flow of coolant to speed up the warming of a cold engine. When the thermostat gets stuck in the closed position, coolant stays in the engine and quickly becomes overheated, resulting in engine overheating.Blocked Coolant PassagewaysRust, dirt and sediment can all block or greatly impede the flow of coolant through the cooling system. This can limit the system's ability to control engine temperature, which may result in higher operating temperatures and engine overheating. Once again, a flush and fill is recommended to remove debris.Faulty RadiatorBy passing through a series of tubes and fins, coolant temperature is reduced in the radiator. Leaks and clogging are some of the most common causes of radiator failure. Any disruption in the radiator's function can lead to elevated engine temperature and overheating.Worn/Burst HosesA hose that contains visual cracks or holes, or has burst will result in leaks and disrupt the flow of engine coolant. This can result in overheating.Bad Radiator FanA fan blows air across the radiator fins to assist in reducing the temperature of the coolant. A fan that wobbles, spins freely when the engine is off, or has broken shrouds will not be able to reduce the temperature to proper level, thus possibly resulting in engine overheating.Loose or Broken BeltA belt is often the driving link that turns the water pump at the correct speed for proper coolant flow through the cooling system. If a belt is loose or broken, it cannot maintain the proper speed, thus resulting in poor coolant flow and ultimately, engine overheating.Faulty Water PumpKnown as the 'heart' of the cooling system, the water pump is responsible for pressurizing and propelling engine coolant through the cooling system. Any malfunction of the water pump, including eroded impeller vanes, seepage or wobble in the pump shaft, can prevent adequate coolant flow and result in engine overheating.ALSO IN THIS SECTION:HOW A COOLING SYSTEM WORKSSYSTEM MAINTENANCE & RED FLAGSCOMMON CAUSES OF OVERHEATING
Air Conditioning and Heat for Chevrolet HHR Panel LT New Cars Logo
What can cause my car to overheat only when my radiator cap is on
Car Overheating? Why your Car Overheats & How to Fix It
www.vikingspeedshop.com/car-overheating-fix-prevent-future/
Rating: 4.2 - ‎51 votes
Oct 30, 2015 - The biggest cause of this is a faulty thermostat that is stuck closed. ... If the radiator cap were to be at fault you most likely would see steam from boiling coolant. My car only overheats when I accelerate hard or drive hard!
Why Is My Car Overheating and What to Do? - EnkiVillage
www.enkivillage.com/why-is-my-car-overheating.html
An overheating car can be caused by many problems. ... Why Is My Car Overheating: Possible Causes .... If you do open the hood, try to do so only when the car is cooled down. ... Never open the radiator cap while the radiator is hot, as the release of pressure could lead to serious ... I wonder if my radiator might be clogged.
Common Causes of Overheating ' ASC Industries, Inc.
asc-ind.com/cooling-system.../common-causes-of-overheating/
... injury, never, ever attempt to remove a radiator cap while the engine is hot! Anoverheated engine can be caused by anything that decreases the cooling system's ...Possible leak points include hoses, the radiator, water pump, thermostat housing, ... Be sure to use the coolant recommended by your vehicle's manufacturer.
Diagnose Engine Overheating - Auto Repair Help
www.auto-repair-help.com/auto.../diagnose_engine_overheating.php
Feb 09, 2016 | Cars & Trucks
car dies when i come to a stop and when i drop to 1st gear
hi,
Jul 14, 2015 | 2003 Ford Escort - ZX2 - Ltd. Edition...
my 1987 corvette coup motor gets hot real fast , I check therostat and thats not the problem , any idea what else it can be ?
Could be a faulty temperature sensor, at wost it's going to be a bad head gasket or intake manifold. Sorry for the bad news and hope that it's just a faulty temp sensor.
Thank you for using fixya and check your engine oil to make sure there is no coolant mixing in with your engine oil. Coolant is corrosive to your engine's internal bearings.
Sep 21, 2010 | 1987 Chevrolet Corvette
880 people viewed this tip
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
