Tip & How-To about Philips SAC2530 - CD/DVD repair kit (SAC2530/27) CD-R Media
How to repair memory card
  1. Download and install a data recovery program. The first thing you want to do when you encounter a memory card error is to attempt to recover important files. There are a number of programs available to accomplish this. Photo Rec is a powerful, free option for most operating systems, but lacks a graphical user interface, which can be intimidating for less advanced users. Find the data recovery program you are most comfortable with in terms of price and features.
    Insert the memory card into your computer's memory card reader. Use a USB card reader or connect your device to your computer via USB if your computer does not have a card reader.
    • Some devices require that you enable disk use via USB through its settings before your computer will recognize it.
  3. 3
    Run your data recovery program. Follow the procedure to recover files for your data recovery program and recover what you can from your damaged memory card.
  • 2
    Go to Computer. Open the Start menu and click Computer. Type Computer into the search box if you cannot find it.
    • In Windows 8, Computer is called This PC, and can be found by searching forComputer from the Start screen.
  • 3
    Find your memory card. Your memory card will be listed under Devices with Removable Storage (Devices and drives in Windows 8). It should be named something like "Removable Disk (M:)". Make note of the drive letter, as it will be needed later.
    • If you cannot tell which disk is your memory card, remove your card with this window open and note the drive that disappears. Remember to reinsert you card before continuing.
  • 4
    Open Command Prompt. From your desktop, press ? Win+R to open the Run dialog. Enter cmd and click OK.
  • 5
    Run Check Disk fix and recover. On Command Prompt, type chkdsk m: /r, where m: is the drive letter of your memory card, then press ? Enter to begin.
    • Depending on the errors found during this process, Check Disk may ask for your input in regards to what action it can take. When this occurs, answer "Yes" and press enter to continue.
    Part 3 of 3: Repairing a Memory Card on Mac
    1. 1
    2. 2
      Run Disk Utility on your Mac. Disk Utility is a Mac operating system utility that can perform disk-related tasks. Select Go from your Finder menu and select Utilities or press ? Shift+? Command+U from the Finder to open your Utilities folder. Open Disk Utility from your Utilities folder.
    3. 3
      Select your memory card. Find your memory card on the list of connected drives. If you do not know which drive is your memory card, remove it and reinsert it to determine which drive it is.
    4. 4
      Repair your memory card. In the First Aid tab, check the "Show details" box, then click Repair Disk. If Disk Utility reports any errors, repeat the repair process until it finishes and reports "The volume appears to be OK".
  • Posted by on
    Philips SAC2530 - CD/DVD repair kit (SAC2530/27) CD-R Media Logo
    i am unable to transfer pictures from camera to computer due to card error,is there anyway i can?
    you can recover photos from camera with photo recovery program like asoftech photo recovery. You can connect camera's memory card to computer, then download this picture recovery program
    http://www.softpedia.com/get/System/Back-Up-and-Recovery/Asoftech-Photo-Recovery.shtml
    Jul 05, 2011 | Samsung Cameras
    WHEN CAMERA IS TURNED ON IT SAYS CARD ERROR
    Remove the card from camera and then connect the card to computer with a card reader, and then recover files from card with a card recovery program, recommended asoftech data recovery that helped me before.
    http://www.facebook.com/pages/Asoftech-Data-Recovery/290956907592436?sk=info
    Apr 07, 2011 | Fuji FinePix A345 Digital Camera
    the memory card loses data what should i do
    download this memory card data recovery program
    i have used this once to recover a file off my sd card and it worked... hopefully it works for you too!!!!!
    Jan 11, 2011 | Samsung B3410 Cell Phone
    To recover my 2gp micro sd memory card
    you can recover memory card with card recovery software like asoftech data recovery, download the software with link below
    Memory Card Recovery Software
    Jul 07, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Format problem
    Do not format the card, try photo recovery software to rescue the lost photos, here are some you may rely on. Both programs can also recover videos and music.
    Photo Recovery Software (for Windows)
    Mac Photo Recovery Software (for Mac OS X)
    Be careful: Before your pictures are recovered, do not attempt to save more files to the SD card in case the original files(your pictures) are overwritten.
    Dec 18, 2008 | PNY Optima 1GB PC2-5300 DDR2 SoDIMM...
    360 people viewed this tip
    Top Philips Electronics - Others Experts
    Electro Med Services...
    Bill Boyd
    Tom Chichester
    Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
