Tip & How-To about ErrorExpert
Blue screen error
  1. To run Startup Repair using preinstalled recovery options
    1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
    2. Do one of the following: ...
    3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter.
    More items...
Computers & Internet Logo
reset to factory settings
Did your computer come with a recovery disc, Windows disc or have you create a recovery set of discs?
If after reading all of this you find yourself overwhelmed or unwilling to try, take it to a shop.
Another option to the below copied from the Help section to reach the Recovery would be to open the Control Panel. If Category view, under System and Security, select Back up your computer, then Recover system settings, **Then Advanced recovery methods. If in Icon view, select Recovery and you will be at the ** above. There's where the discs above will come into play. If.you don't have any of those, you will have to hope they have a hidden partition on the drive containing the recovery which will either show itself there or in the F8 process below..
To open the System Recovery Options menu on your computer 1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer using the computer's power button.
*If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
*If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press Enter. (If Repair your computer isn't listed as an option, then your computer doesn't include preinstalled recovery options, or your network administrator has turned them off.)
4. Select a keyboard layout, and then click Next.
5. On the System Recovery Options menu, click a tool to open it.
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
    • If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.
Dec 07, 2014 | Acer TravelMate Computers & Internet
My netbook wont load up it says following file is missong or corrupy: \WINDOWS\STSYEM32\CONFIG\SYSTEM You can reapair by insecting disc. Thing is its a net book and dosent have a disc what can i do?
try to follow this prosedure if you have XP . i recomend you part 2.
http://support.microsoft.com/kb/307545.
If you have a Windows Vista installation disc:
  1. Insert the installation disc.
  2. Restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click the arrow next to the Lock button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c.png, and then click Restart.
  3. If prompted, press any key to start Windows from the installation disc.
  4. Choose your language settings, and then click Next.
  5. Click Repair your computer.
  6. Select the operating system you want to repair, and then click Next.
  7. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem, and if necessary, it might restart your computer as it makes repairs.
If Startup Repair is a preinstalled recovery option on your computer:
  1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
    • If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
  3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include Startup Repair as a preinstalled recovery option.)
  5. Select a user name and enter the password, and then click OK.
  6. On the System Recovery Options menu, click Startup Repair. Startup Repair might prompt you to make choices as it tries to fix the problem and, if necessary, it might restart your computer as it makes repairs.
hope this help
Dec 06, 2010 | Acer eMachines eM2501162 Netbook
how to access the recovery console from startup
Click the Start button , and click Restart.
Note:If your computer is not configured to start from a CD or DVD, check the information that came with your computer. Just tap F12 while booting to force boot from cd or You may need to change your computer's BIOS settings to boot from cd. 4. Choose your language settings, and then click Next.
7.
If your computer has preinstalled recovery options:
3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include the System Recovery Options menu as a preinstalled recovery option.)
6. On the System Recovery Options menu, click a tool to open it.
Please take time to rate this fixya.
May 11, 2009 | Toshiba Satellite A105 Notebook
my computer shuts down acer programs wont run
Click the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, click the arrow next to the Lock button getopencontent.aspx?assetid=eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c&documentset=en-us&renderkey=xml, and then click Restart.
May 05, 2009 | Acer Aspire 5050-3242 Notebook
I NEED A RECOVERY DISC FOR GATEWAY LAP TOP IT HAS WINDOWS VISTA HOME PREMIUM IT IS BRAND NEW I DOWN LOADED A PROGAM IT MESSED IT UP
a lot of computers don't come with a recovery disk.
The System Recovery Options menu in Windows contains several tools that can help you recover Windows from a serious error. You can perform repairs to the files that Windows uses to start itself, perform a restore operation using System Restore, and restore your entire computer and system files using backups that you have made previously.
Note
  • If your computer does not include the System Recovery Options menu, your computer manufacturer might have provided other recovery options. Check the information that came with your computer or go to the manufacturer's website for more information.
  • If your computer has preinstalled recovery options:
      Click the Start button getcontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=signed1, click the arrow next to the Lock button getcontent.aspx?assetid=eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c&documentset=en-us&renderkey=signed1, and then click Restart.
    7. i hope that this will help you.
Aug 16, 2008 | Gateway Computers & Internet
427 people viewed this tip
Top ErrorExpert Computers & Internet Experts
David Payne
David Payne
Are you an ErrorExpert Computer and Internet Expert? Answer questions, earn points and help others
