Tip & How-To about Miscellaneous
How to park your car in the sun without burning your hands on the steering wheel when you get back in the car.
When parking your car in the summer time it is hard to avoid that hot sun-and burning your hands on the steering wheel when you get back in the car! To avoid that burning sensation make sure to turn your steering wheel around when you park the car. That way-the part that touches your hands will not be in direct sun.
Miscellaneous Logo
Why is my power steering hard to turn right in the morning during cold days
Sounds like combination of steering box ready to fail along with fluid change in power steering due.
Jan 21, 2016 | 2001 Dodge Grand Caravan
Steering wheel slips/feel notchy
Has belt been inspected, tension checked?
Mar 04, 2014 | 2011 Cadillac CTS-V
wheel is hot
Cover the windscreen from the sun light while parking.
Jan 25, 2014 | Toyota Avensis Cars & Trucks
Turned steering wheel after powering off cuz I am parked on a hill...it locked up and now the ignition is locked too...how can I start the car?
your steering wheel lock is connected to ignition in column, pull hard on steering wheel in direction wheels are turned at the same time turn key, this should free them both up.
May 18, 2010 | Subaru Impreza Cars & Trucks
Steering wheel locked in place, key will not turn...
Very likely the steering thrust stored in the tires attempting to turn back is forcing excessive tension against the steering lock.
Try (very hard) to turn the steering wheel either direction while turning the key gently.
If that solves it you can avoid this by letting go of the steering after stopping to park, turn off the ignition slowly (engine off, pause, then key out). This will ensure that the steering wheel comes to rest prior to locking the column.
Jul 10, 2009 | 2000 Nissan Xterra
103 people viewed this tip
Top Miscellaneous Experts
Helen Franco
Helen Franco
Level 1 Expert
Crash Moore
Crash Moore
Level 1 Expert
Edmund Perozzi
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
