Tip & How-To about Ovens
How to Repair Whirlpool E6 F2 Oven Code
Your Whirlpool Built-in Oven has failed and the electronic control is no-longer-available. You can have this control board rebuilt!
The common symptom is a display that intermittently goes blank, accompanied by an error code E6-F2. This is caused by a failure in the electronic control board (EOC).
The courteous technicians at www.fixyourboard.com in Austin Texas can rebuild this for you!
Control Board Part Numbers: 8302967, 4451856, 4451991, 4452890, 4452898, 4453664, 4453664.
Applicable Models: GBD277PDB6 GBD277PDB7 GBD277PDB8 GBD277PDQ6 GBD277PDQ7 GBD277PDQ8 GBD277PDS6 GBD277PDS7 GBD277PDS8 GBD277PDT6 GBD277PDT7 GBD277PDT8 GBD307PDB6 GBD307PDB7 GBD307PDB8 GBD307PDQ6 GBD307PDQ7 GBD307PDQ8 GBD307PDS6 GBD307PDS7 GBD307PDS8 GBD307PDT6 GBD307PDT7 GBD307PDT8 RBD245PDB11 RBD245PDB12 RBD245PDB13 RBD245PDQ11 RBD245PDQ12 RBD245PDQ13 RBD245PDS11 RBD245PDS12 RBD245PDS13 RBD245PDT11 RBD245PDT12 RBD245PDT13 RBD275PDB11 RBD275PDB12 RBD275PDB13 RBD275PDQ11 RBD275PDQ12 RBD275PDQ13 RBD275PDS11 RBD275PDS12 RBD275PDS13 RBD275PDT11 RBD275PDT12 RBD275PDT13 RBD276PDB11 RBD276PDB12 RBD276PDB13 RBD276PDQ11 RBD276PDQ12 RBD276PDQ13 RBD276PDS11 RBD276PDS12 RBD276PDS13 RBD276PDT11 RBD276PDT12 RBD276PDT13 RBD305PDB11 RBD305PDB12 RBD305PDB13 RBD305PDQ11 RBD305PDQ12 RBD305PDQ13 RBD305PDS11 RBD305PDS12 RBD305PDS13 RBD305PDT11 RBD305PDT12 RBD305PDT13 RBD306PDB11 RBD306PDB12 RBD306PDB13 RBD306PDQ11 RBD306PDQ12 RBD306PDQ13 RBD306PDS11 RBD306PDS12 RBD306PDS13 RBD306PDT11 RBD306PDT12 RBD306PDT13
Ovens Logo
Why the cooling fan does not work on one the upper over of KEBS278
First check that the fan itself has not failed. If the fan and wiring are ok, your EOC (electronic oven control) has failed. This is NLA (no longer availabe). The Whirlpool part number is 3187895. This can be rebuilt: See:
http://www.fixyourboard.com/boards/3187895.html
Aug 24, 2014 | KitchenAid Kitchen Aid KEBS277SWH Double...
KitchenAid Double Oven LED Blank
These ovens are made by Whirlpool. The electronic control board is notorious for going bad. If it is the one I am thinking about it is probably no longer available and will need to be rebuilt. I have had good success with Corecentrics Solutions. A google search will bring them up. I sent off the board and a rebuilt one arrived in about a week. Much cheaper than the original board too.
Nov 26, 2013 | KitchenAid Ovens
e2 f6
E2 F6 means that your oven temperature sensor has failed as well your electronic control board.
The oven temp sensor, electronic control board and the touchpad must be replaced.
Before you decide what to do, check the thermal fuse at the control panel first. If blown, replace it and the temp sensor. If you are lucky the control board may still be good.
Jun 01, 2011 | Whirlpool GBD307PD Electric Double Oven
oven shut off not working
First make sure you have power to the control board. If so, the control board has failed. It is no-longer-available but can be rebuilt by fixyourboard.com.
Aug 01, 2010 | Whirlpool RBS275PD Electric Single Oven
951 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
