Tip & How-To about Microsoft Computers & Internet
Windows 10 - Start Menu Fix
How to fix the Windows 10 Start Menu when you can only right click on it:
1. Right Click the Start/Window button on the bottom left corner of the taskbar.
2. Select "run command prompt as administrator"
3. Type in the word "powershell" without the quotes and hit Enter. Wait a few seconds to process the request.
4. Copy and paste the block below and hit Enter. It will take about a minute to process. Don't close the window, just wait for the command prompt to reappear. Then your start menu button will work again!
Regards,
Terry Wilkie
Get-AppXPackage -AllUsers ' Foreach {Add-AppxPackage -DisableDevelopmentMode -Register "$($_.InstallLocation)\AppXManifest.xml"}
Computers & Internet Logo
How to Mod Using Modio?
    1)SB Flash drive for Xbox
    2)Choose game save you want to mod, and move it to USB
    3)Take USB out of Xbox and plug into computer
    4)Open up Modio 5
    5)Check button that says gamesaves
    6)In bottom right of window, there's a search bar, where you can type the name of the game
    7)Find a file you want to download and double click it
    8)Click button in bottom right of new window
    9)Exit out of windows and main menu for Modio
    10)Click Open save from device from main menu
    11) Leave window open, you will need it later
    12)Click on open and save on main menu
    13)Find file you downloaded earlier, and double click it
    14)Put save file from device on right side, put other file on left side
    15)Left side window bars delete them all
    16)Copy numbers from right side window, and paste them in corresponding bars on left side window
    17)Close out right side window
    18)In bottom right of remaining menu, click button that says rehash and resign
    19)Find button on open window that says Save to device
    20)Take out USB and plug into Xbox
    21)Move modded file onto Xbox
Oct 20, 2016 | Video Game Consoles & Games
How to Mod an Xbox?
Use Modio 5
    4)Open up Modio 5
Please tell me how to reboot my laptop
If the operating system is Windows XP ...
1. click the start button at the bottom left corner of the desktop
2. at the bottom right of the start menu window that pops-up, click the Turn Off Computer button
3. at the right side of Turn off computer window in the middle of the screen, click Restart button
If the operating system is Windows 7 ...
1. click the round windows logo button at the bottom left corner of the desktop
2. at bottom right of start menu window that pops-up, click on Shut down right arrow for options
3. on the pop-up list of options window, click on the Restart item
Apr 30, 2011 | Toshiba Computers & Internet
loaded mozilla and screen did not appear fully.
Right click on the bar along the bottem of the screen, and a menu should pop up, near the top of menu click cascade windows, the mozilla window should go to the top left corner of your screen. with the mouse cursor go to the bottom right hand corner of the window and an arrow should appear keep the right click button held down and drag the window diagnally towards the bottom cornner of the screen and you should then have full screen window.
Jan 22, 2010 | Mozilla Firefox
optiarc ad 7530a dvd rw drive
I have seen this problem many times. 99% of the time this will fix it for you. The first part of this fix is to backup the current registry just in case you need to go back.
Try this. I really think it will fix your problem :)
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
Mar 19, 2008 | Computers & Internet
1,362 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
