Tip & How-To about Miscellaneous
Rice cooking
This morning I have encountered a great many questions on rice cookers, so I remembered the time when I had one and why I started cooking rice again.
The rice was beautifully cooked in the cooker, but it took up too much space on my kitchen bench. So I turned to pots and the micro.
Cooking rice in a microwave
  • take 1cup water
  • 2 cups rice
  • a pinch of salt
  • put the water, salt and rice together in a bowl with a lid
  • blend well
  • put the lid on the bowl
  • put the bowl into the micro
  • on the micro, keep full force and set the timer on five minutes
  • start the cooking
  • after five minutes open the micro, open the bowl and stir the rice with a fork.put the lid on again keep the micro going for another 10 minutes.
  • repeat the stirring prosess, until the rice is nice and fluffy andready to serve.
Cooking rice in a pot with a lid.
  • take 1cup water
  • 2cups of rice
  • pinch of salt
  • put the ingridience in a pot, and an oven safe pan
  • in the pot, now with a tight lid. Put on a cooker on highest temperature for five minutes.
  • open the pot, stir the rice with a fork.
  • lower heat and cook for another 15-20 minutes,, stirring occasionally.
  • the rice is cooked when fluffy.
Cooking rice in a pan in the oven
  • Put the temperature in the oven on 150 degrees Celsius
  • put the ingridience as in the recipe above in a pot and start boiling
  • remove from pot into a ovesafe bowl or pan
  • Cover bowl/pan and cook further for another. 20 minutes.
Miscellaneous Logo
Is a pressure cooker any good for cooking pulses and rice etc?
Yes - I think it's a great way to cut down on the time needed for cooking. I particularly love using my pressure cooker for beans which I soak over night and then they only take 20 minutes in the pressure cooker. It's also great for rices like brown rice that take 40 minutes when boiling - it cuts the cooking time by half.
Feb 14, 2013 | Home
need basic directions
There is a cup that comes with it that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup that you want to end up with...
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line....
If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
remeber also if you have a brown rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
These things are really goof proof and make great rice very easily...
heatman101
Jul 26, 2010 | Aroma ARC-914S 8-Cup Rice Cooker
digital oster 20 cup capacity rice cooker wont turn on
Rice cookers will only cook if you have enough water in it. If all the water has cooked out, then the cooker will turn off. Remember when you put your rice in the cooker, make sure you level it off. Then add twice as much water so that it will over cover the rice.
Nov 18, 2008 | Oster 3072 20-Cup Rice Cooker
140 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
