Tip & How-To about Microsoft Windows 7 Ultimate for PC
How to speed up operating system?
Remove unused softwares and install them as required and try to remove temporary files by go to Run and type %temp% and select all folders and files simply delete them all...
Microsoft Windows 7 Ultimate for PC Logo
compaq presdio slow desktop windows xp
Follow these steps to fix computer freezes problem::
  • Remove unused programs
  • Install and run antispyware software
  • Free up wasted space with Disk Cleanup tool
  • Defragment your hard disk drive
  • Disconnect unused network connections:
Click Start, and then click My Computer.
On the Tools menu, click Disconnect Network Drive.
Select the network drives that you no longer need, and then click OK.
ALSO
Stop Unwanted startup programs:
Start > Run > write msconfig > Click on StartUp tab
Deselect the programs you want to stop
Delete Temporary Internet Files:
Click Start - Run, type in %temp% and then click OK.
Once that temp folder is open and you can view its contents, select and delete EVERYTHING that's inside it.
Repeat the steps with c:\windows\temp
After you're done with both temp folders, restart the computer.
Services:
Click Start, type services.msc in the Search box. Press ENTER. Right click and stop each service which is not necessary for you.
For an instant fix use Intel Software Partner Reginout. WebRepOverall ratingThis site has no rating(not enough votes)
Dec 13, 2012 | Compaq Presario 5000 PC Desktop
cant load roxio 2011 code error oood plaese tell me what to do its been 6hrs now cleaned everything please please
Please refer to the steps below and follow it carefully as it will help you resolving the problem.
  1. Disable your startup applications using MSCONFIG. This will disable any unnecessary background or system tray applications from loading.
    • Go to Start -> Run. Type "msconfig" (without quotes) then click OK.
    • Select the Startup tab.
    • Click the Disable All button.
    • Click the Apply button, then click the OK button.
    • Click the Restart button.
    To reverse this at the end of installation, go back into MSCONFIG and select Enable All and restart (that can be done once installation is complete).
  2. If you are installing from a physical disc, please try to copy the content of the disc to a folder on your hard drive then install from the hard drive. To do this:
    • Create a new folder on your Desktop.
    • Go to Start -> My Computer, then right-click on the Creator installer disc and select Explore.
    • Select ALL of the files in the installer window and copy to the folder you just created.
    • To install from the folder, double click the setup.exe file.
  3. If you are installing from downloaded files, please follow the steps below to delete the temporary files then try to reinstall again.
    • Go to Start -> Run. Type "%temp%" (without quotes) then click OK. The Temp folder will show up.
    • Go to Edit -> Select All.
    • Go to File -> Delete.
    • Reinstall software
Jan 06, 2011 | Roxio Creator 2011
it crashes every time i start it,,,,
Completely uninstall the browser and remove it from the temporary files by typing "%temp%" in the Run box. Also, clear the unused or old registry files using software like "ccleaner". Once you are done with these steps, you can re-install the browser using the Setup file if you have. Installation of this requires internet connection.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 11, 2010 | Google Chrome
UNABLE TO DOWNLOAD ITUNES TO MY unable to download itunes this is tghe messg I get: : C:\Documentsand Settings\DELL\Local Settings\Temporary Internet Files\Content.IE5\XMB6JTLP\iTUNES SETUP[1].EXE IS NOT VALID Win32 application UNABLE TO DOWNLOAD ITUNES TO MY unable to download itunes this is tghe messg I get: : C:\Documentsand Settings\DELL\Local Settings\Temporary Internet Files\Content.IE5\XMB6JTLP\iTUNES SETUP[1].EXE IS NOT VALID Win32 application Cancel
It is required to clear the temporary folder before downloading the Software. For this click 'Start' button then select 'Run' (you can open 'Run' by press and hold Windows button on the keyboard and then pressing alphabet key 'R'). Type '%temp%' inside the Run window, and you will get a folder opened. Delete all the files in the folder and close it. Now try to download the Software, it will work.
All the best.
Sep 21, 2010 | Dell Computers & Internet
I am receiving error code 0643 when I try to install Roxio Creator 2010 Pro and then program uninstalls.
    • Reinstall your software.
Jun 11, 2010 | Roxio Easy Media Creator 10 Suite
1,059 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
