Tip & How-To about Computers & Internet
How to download youtube videos
You should get YTD video downloder.[How to get videos] 1st you have to make a file and then go on YTD and select that folder so when you get videos it will spawn there,[How to get the VIDEO] you need to copy the link of the video you want and you do not need to paste it because it does it for you.I hope this helps. By Danthedimond gamer,about YTD Downloader
Computers & Internet Logo
How to download undownloadable youtube videos ?
Jul 11, 2015 | YouTube Computers & Internet
i want to add videos to my phantom but i don't know how?
It's much like adding audio files to your Phantom, First connect the media player to the computer with the USB cable and choose 1) Power and Data. The media player will show in the list of available drives; your micro-SD card will show as another drive if you have one installed in the media player. Drag the video files from your computer's hard drive to the Video folder on the media player (or its micro-SD card). Then drop the files into that folder. Create the folder if needed before you use it. For Windows systems, the easiest way to drag files between folders is to press the Windows key and E together. Then repeat the key press. Now you have two instances of Windows Explorer. Re-size the windows so that you can see both at the same time. Navigate to the folder with your videos in one window. Navigate to the video sub-directory of your media player or micro-SD card in the other window. Select your videos by either left-clicking on them, hold that click and move to the other window and then release the left mouse/touch pad button. Alternatively, right-click and drag the file. When you release the right button, you will be prompted to Copy, Move or Cancel. Note: the media player may not be able to decode all videos. It should handle AVI, WMV, MPEG and RMVB files, among others.
If the videos you want to move to the media player are on-line, you will need to download them first to your computer first. There are extensions and apps that allow you to download You Tube videos. One is YTD Video Downloader: http://download.cnet.com/YTD-Video-Downloader/3000-2071_4-10647340.html .
For details on the options when you connect the USB cable to a computer, see the manual: http://visual-land.com/downloads/phantom_manual.pdf .
I hope this helps.
Sep 03, 2013 | Visual Land Phantom 8GB Media Player
my coby mp600-2g does not play video. After uploading it to my player and turning it on, all it does is freeze when selecting the video.  It shows the "play" symbol in the bottom left corner and then freezes.  any ideas how to make it work?
I had the same problem with playback of video with coby mp60-2g, and it took a couple of weeks to figure out. I wasted a lot of time installing video file converters, and trying to convert my wmv files to MTV,.... it wasn't necessary!
The Coby Media Manager software that comes with the device actually works for converting wmv files (for example) to mtv files. It's just a little confusing HOW IT WORKS. Unfortunately the 'Coby Media Manager User Guide' is very little help.
The key really is 'Synchronizing' your video to your player! But there's a little organizing of your files to do before-hand, which makes it easier when your ready to playback on your device.
For me it was easier to separate my audio files from my movie files in the 'Device' tab of the Coby Media Manger. This was the 'F:' of the Device content (middle third of the manager window) for me. I put the videos in the MOVIE.DIR folder. But you can't synchronize the video here. You must click on the 'Movies' tab on the left side of the manager window.
Under Movies, go to Library,... (now it gets a little confusing),.... immediately under 'Library', there is a 'Folder',....but that only shows what you have selected by clicking on the 'Video Folder', a little further down and slightly to the right.
So you must make your selection ('Import' video files and folders) by clicking on the 'Video Folder'! When you click on this Video Folder, you'll open a selection box, which offers
-Documents
-Music
-Pictures
-Videos
-C:\
-F:\
If you select only 'Videos', it will automatically select 'C:\', also.Which will import ALL of your videos on your C:\
If you select only 'F:\', it will only import the videos which you have put (as I suggested earlier) in the 'MOVIE.DIR' folder at the 'Device' tab.
NOW TO SYNCHRONIZE,....! (make sure you mp3 is connected to your computer).
You might notice, that if the device (mp600) already contains the file, then there will be a small icon which looks like the mp3, next to the file under the 'status' column.
BUT that doesn't mean that the mp3 will actually 'play' the video. It must ALSO be 'Synchronized', :o).
Once you've made it this far, Synchronizing is easy. Let's assume that you decided to Import all of the videos in C:\, and F:\ when you clicked on the 'Video Folder'.
Now if you go back up to 'Folders', and click on it ALL of your video files will be dislpayed. And the files which are already on your device will have the mp3 icon next to them. Also, when you clicked on 'Folders', additional sub- folders were displayed under the Folders icon.
The easy way to 'Synchronize', is to select the F: folder, with a 'right click',... which gives you the synchronize option,... clicking 'Synchronize' will synchronize-convert-copy all of the video files in the folder! Now, if you go back to the 'Device' tab and look at the video files, you'll see they have all been to converted to mtv files!
Now when you open your mp600, and arrow to 'Movies', you'll be able to play your videos!!
Jun 22, 2009 | Coby MP-C7097 MP3 Player
sound drive
downlod the audio driver from the following link:
http://cid-3a2fd42defd10b67.skydrive.live.com/self.aspx/Public/Audio%20driver.zip
After downloading the file please extract the files to a folder on the desktop.
Follow the below steps to install the driver correctly:
1. Click on Start and select Run. Now type devmgmt.msc and press enter.
2. Right click on "Audio device on High Definition Audio Bus" and click Update driver.
3. Select not at this time, click on next and Select "Install from a list or specific location".
4. Click Next. Then select "Don't search, I will choose the driver to install"
5. Click Next and then select "Sound, video and game controller" from the list.
6. Click Next and then click Have Disk.
7. Click Browse, Choose the location where you have saved the extracted folder.
8. Open the folder and choose the .inf file listed.
9. Ignore any errors you receive and proceed with the installation.
Sep 12, 2008 | Compaq Presario 700 470024-192 Notebook
717 people viewed this tip
David Payne
David Payne
