Tip & How-To about Home Security
Troubleshooting 101
Is your alarm beeping? Is it not working like it should be? No need to panic, it's already broken, now it's time to fix it! You need two things to find out what the problem is. The first is a manual for the alarm system. Locate the main metal box where all the wires are ran to and look for a white sticker on the board. If you can't find anything that is close to a manufacturer name look at the panel door for a manufacturer and version. If both of those options fail take a picture of the keypad and post it where it can be identified by someone with a knowledge base. The second item you need is a digital meter. If you don't have a digital meter pick one up at Harbor Freight (sometimes you can find them for free!).
Once you have the manual in hand you can begin troubleshooting. If your system has power great, if not use your manual to locate where the power terminals are located and your meter to see if you have power. If you're unfamiliar with using meters there's lots of YouTube videos that can assist you. This link https://www.youtube.com/watch?v=4QZ57aFQvNc is just one example. If you don't have power, is the panel plugged in? If so, is the outlet working? If your outlet is working, the panel is plugged in, it sounds like you have a bad transformer. Buy a new one that matches the old one's specifications and you'll be ready to go.
Maybe your system has power but is going off all time for no reason. First, you need to find out what zone is going off. After you have located the zone you have to determine if it's hardwire or wireless. If it's a plastic box, chances are it's wireless and the battery needs to be changed. Examine the box closely and look for an area were a small screwdriver could be used to open the box. Be careful!! The clips break! See what battery is in it and replace it. If it's a hardwire system it's a little bit more difficult, it would be best to leave that up to the professionals.
One last tip is to go to the troubleshooting section of your user manual. Often times it will have great instructions on how to pinpoint down the problem with specific troubleshooting techniques for each panel. Most of the time it has to do with different lights that are being displayed on the keypad. There's a lot more that could be said on this topic but this is only Troubleshooting 101.
God Bless,
Timothy
Home Security Logo
my viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
I just bought my Iron Man watch a couple of weeks ago and all of a sudden my alarms/timer won't work. The indiglo light flashes but there is no sound or beep. I tried resetting it by pressing all the buttons at once and it did reset it but I still can't hear the beeps or alarms despite turning on when I set the date/time. I don't want to have to buy a new one already or spend the time and money to send in to Timex to either have it fixed or replaced. Can you help me out?
check the caseback of your watch, hold it upright turn it around. look at the markings, if the markings is doesnt match the upright postion you have to open it then put the caseback on its proper position because the part that is beeps is attached on the caseback and the machine has small spring to connect power on it. i hope i had been helped you.
Sep 06, 2011 | Timex Sports Ironman Triathlon 100-Lap...
kia rio key fob power lock/alarm problem
if the lights flash when you hit the panic button but the horn does not beep, then the alarm horn is bad. Vehicle has a second horn just for the alarm
Sep 16, 2009 | 2003 Kia Rio
679 people viewed this tip
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
