Tip & How-To about Whirlpool WMH31017AW
Error Code F8E5
F8E5 Exhaust air template detection failure 1. Press CANCEL - CANCEL - START, verify failure code, and then press CLOCK/OPTIONS to display the exhaust air temperature sensor reading. Verify the sensor temperature reading is at room temperature (typically 50?F to 90? [10?C to 32?C]) and verify failure code. If failure code matches complaint, continue to Step 2. 2. Unplug microwave oven or disconnect power. 3. Disconnect sensor from ACU PCBA. 4. Measure HF NTC resistance between connector pins and confirm reading is between 9.5k??and 10.5k??at room temperature. If measurement is not correct, or if a short or open circuit is found, replace sensor. 5. Replace all parts and panels before operating. 6. Plug in microwave oven or reconnect power. 7. If the sensor temperature reading is still not correct, replace ACU PCBA. 8. If failure does not appear, stop.
Whirlpool WMH31017AW Logo
Tiffany microwave
We have this microwave in our caravan and its taken me about 20 holidays to figure this clock out. So I'm sorry i'm a bit late on this but its taken me until now to figure this out.
Step 1. Press the clock button.
Step 2. Press the cancel button. (the display will return to zero)
Step 3. Enter time using the 1 to 0 numbers.
Step 4. Press the clock button.
Seems so simple now I know how.
Jul 22, 2013 | Microwave Ovens
sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have a whirlpool microwave oven over the range. Model GH 5184xps-4 when I press start, it comes on for one second then it shows a code -F7- and stops
    TOUCH PANEL & MICROCOMPUTER BOARD TEST FOR WHIRLPOOL....
    The microwave oven may be provided with a self diagnostic routine that can be operated
    through the touch pad keyboard. To enter the self-diagnostic routine:
    1.While pressing the CANCEL keypad:
    a) Open the oven door.
    b) Unplug the microwave oven for 2-seconds and plug it back in.
    c) Release the CANCEL keypad and close the oven door. You will see the following display.
    CHART
    NOTE: The humidity sensor test results will appear on the display after 8-seconds.If the tests are successful, "OK " will be displayed. If one or more of the tests fail, "ERR " will be displayed.. 2.When a keypad is pressed, a number according to the test chart will be displayed. When no keypad is pressed, a blank "O" (square) is displayed...
    POWER FAILURE & FAILURE CODES
    Power Failure: After a power failure, the WELCOME screen will be displayed.
    F2 Keyboard Failure: Refer to the Tech Sheet and conduct a touch panel continuity test.
    F3 Humidity Sensor Failure: Refer to the Tech Sheet and test the sensor.
    F6 Microwave Relay Failure: Check the microwave relay.
    F7 Microcomputer Board Failure: Change the microcomputer board.
    Hope helps.
    Apr 12, 2011 | Whirlpool Microwave Ovens
    I have lost the manual for my Kenwood K25MSS10 microwave oven. Please can you explain how to set the clock?
    Press Clock, then Cancel. Time will display 0. Press numbers to enter time (in 12hr format). Press Clock. Done!
    Mar 31, 2011 | Microwave Ovens
    how do i set the clock on my Kenwood k25mss10 microwave? I have lost the manual.
    Press Clock, then Cancel. Time will display 0 Press numbers to enter time (in 12hr format) Press Clock Done!
    Mar 12, 2011 | Microwave Ovens
    2,897 people viewed this tip
    Top Whirlpool Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Jaime Hernandez
    Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
