Tip & How-To about Pentair 140315 Swimming Pool/spa Sand Filter Trc100c
Triton 2 tr60 sand filter tank
My tank on a tr60 with only 20psi is the max I get on pressure well guess what the bottom is cracked, no problem get a new one. Not at almost 900.00 so I thought about it and came up with this, wet vac sand out disconnect the tank from lines, unscrew in side line on the top, remove fingers from the bottom assembly, in screw that pipe now all you have is a tank with 2 fittings and a drain. Go buy same fiberglass repair kit and start sanding inside and outside (outside is very important to get the gel coat off) and apply your glass I used a sheet then on top of that I used a mat and another sheet that is inside, on outside I used mat then four sheets first pict is the crack before doing anything second is the finished product that cost me 8 hrs of time and 34.00 kit for fiberglass from Home Depot. (NOTE WARNING I WOULD NOT ATTEMPT THIS ON HIGHER PRESSURE TANKS)
Pentair 140315 Swimming Pool/spa Sand Filter Trc100c Logo
suds won't draw from tank
make sure the hose from the tank is not split or cracked where it draws from the tank
Aug 18, 2014 | Honda Black Max 2600 PSI Pressure Washer
how do I fix pin at bottom of clean water tank?
Replace the part. This might mean buying a whole new water tank. You can order most parts online. Have your make and model ready. Find a site by google. ie if it's a hoover enter, "hoover parts".
May 12, 2014 | Hoover Max Extract 60 Pressure Pro Carpet...
03 dodge intrepid I keep having coolant leaks.i fix one leak and I get another... new overflow tank, first...then bleeder valve cracks...fixed... then radiator...fixed..now im leaking fluid from bottom of overflow tank intermiediatly
You may have a blown head gasket thatis pressurizing the coolant system-pull radiator cap off and put a pressure gauge on it and see if pressure goes above 17.5lbs-cheers Denny
Oct 09, 2013 | 2002 Dodge Intrepid
Does a blown head gasket cause pressure build up in a surge tank
could be a air pockets in the coolant system that have top bled out
it is a simple exercise to have a compression test done to check for head gasket or cracked head
Mar 14, 2017 | 1999 Cadillac DeVille
424 people viewed this tip
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
