Tip & How-To about Exercise & Fitness
How to troubleshoot a noisy treadmill
First verify if your are getting the noise with a user physically on the machine, without anyone on, or both.
Creaking or squeaking while running on the machine usually indicates an issue in your incline motor, deck frame, springs, and or pivot points.
A loud grumbling noise getting louder and louder while elevating speed, usually means you have a bad bearing.
Any knocking noise coming from a treadmill indicates bad bearings in your front roller, rear roller, or drive motor.
Isolate the bearings in the front and rear rollers from the drive motor bearings.
To test: Unplug the machine, remove the main shroud, remove drive belt from drive motor and front roller pulley.
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise from the two rollers you can loosen the belt and turn each roller individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your drive motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills pivot points. Incline motor bolt, shaft, deck screws, and or any pivot points on the bottom of your machine. Metal on metal pivot points are usually the culprit in most cases.
Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal on metal needs to be lubricated to minimize wear and tear of those areas.
Synthetic grease works best or any spray on lubrication works fine if you do not want to remove any bolts or hardware.
If you ever find yourself needing technical support, please do not hesitate to call us 888-713-2880 or visit us online at www.sportsmith.net
Exercise & Fitness Logo
what is causing a creaking, squeaky noise to come from the right pedal on my sc5?
Your transmission chain and reduction pulley, and or step chain need to be checked.
It could just be the transmission chain is on just a little too tight, causing the creaking or that the step chain/s just need a little grease on them (which is likely the culprit to any creaking).
If you find you need need any further assistance we would be happy to help you out :) by chat at www.sportsmith.net or by phone at 888-713-2880
We look forward to hearing from you if you need us!
Aug 12, 2015 | Stairmaster Exercise & Fitness
Making very loud whistle noise
Be sure to verify if you are getting the noise while you are physically on the machine or with no one on it
To test: Unplug machine, remove the main shroud, remove drive belt from drive motor and front roller pulley
After doing so, move the treadmill belt by itself by pushing it backward or forward with just your hands and listen for any noise, if you get any noise it is most likely coming from either the front or rear roller. To isolate the noise out of the two rollers you must remove the rollers and turn each one individually.
If no noise with the first test, go ahead and start the machine and run it at a low speed. You want to listen for noise, if you get knocking or grumbling while drive motor is running with no drive belt attached then the issue is in your Drive Motor.
A lot of times simple maintenance will save your treadmill from noise, you want to make sure and lubricate your treadmills *pivot points. Incline motor bolt, shaft, deck screws, and or any *pivot points on the bottom of your machine. Metal on metal *pivot points are usually the culprit in most cases.
*Pivot points are just areas of high friction where there may be a bolt, washer, and nut attached to the base of your frame or any hinges on your folding type treadmills. Metal to metal needs to be lubricated to minimize wear and tear of those areas.
If you have any other questions please do not hesitate to call us or visit us online
888-713-2880 or
http://www.sportsmith.net/supportsearch.aspx
May 29, 2015 | Reebok RX6200 Treadmill Motor Control...
Can up country shocks be used on a non-up country suspension. Worried about the travel and collapsed measurements. Not enough travel or too little?
doubtful the shocks would be the source of any creaking/squeaks. Most creaking and squeak noises are usually a result of worn/dry bushings. I would inspect all swaybar/control arm bushings for dryness and deteriation. Spraying wd40 on all rubber bushings in the rear may cause the noise to subside for a while until you are able to isolate the exactr source
Apr 30, 2015 | 2000 Jeep Grand Cherokee
creaking noise in front end 1997 explorer
Sounds like it is your CV axles.  Turn the wheel one direction, right or left, and check just behind the wheels to see if your CV boot is cracked or ripped (the boot is a black, rubber accordion looking thing).  If it is cracked or ripped, I would say that is definitely the problem.
May 17, 2009 | 1997 Ford Explorer AWD
Very annoying squeaking / creaking during agitation
sounds like trnsmission and brake assembly they are not cheap. you can see one at www.repairclinic.com scroll down to the red(100) click it and look for part number 279566.
Apr 06, 2009 | GE WHSE5240D ENERGY STAR Super Plus 3.2...
837 people viewed this tip
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
