Tip & How-To about Miscellaneous
Mobility scooter gearbox
Is your scooter 6 months or more old ? please consider having the gearbox re-greased ? why ? well sadly most companies use something called grease however it 's awful... from going stiff to having no lubrication properties at all,,, get your gear re -greased , it will prolong the life of the scooter ...and keep the noise away.....
Miscellaneous Logo
I have a 900 series poulan 6"5 HP tiller what type of gearbox oil what weight
The safest to use is oo grease. Snapper used it on all chain and gear assemblies. It's expensive, save yourself the trouble. Go to tractor supply and get something called "Super S Cotton Picker Spindle Grease 00" . It's $5, better staying power than 90w oil and comes in a bottle you can squirt into the fill hole.
Aug 24, 2015 | Garden
iv'e just stripped down and repaired my gearbox on my scooter. however i don't know what oil, grease is required could you help.
hji, on most scooters it recommended you use a semi fluid grease, recommend by shoprider on their scooters... plain grease is not ideal as it sticks to the sides of the casing , not lubricating anything ...
a thickest oil would also be ideal, however remember if no gasket is fitted it may leak...hence the semi fluid route..
http://www.castrol.com/en_us/united-states/products/truck-and-bus/greases.html
Regards
Rob
www.gewizrepairs.co.uk
Aug 05, 2014 | Shoprider Health & Beauty
liteway 4 scooter
hi John, i can't remember what the coupler looked like, so lets recap, your mechanic has fitted to a new gearbox to the existing motor right using the existing coupler ??? , grease or no grease do they connect okay ???
Regards
Rob
www.facebook.com/gewizrepairs
May 26, 2014 | Health & Beauty
DORMEYER stand mixer maintenance
Sadly, the service directions, while excellent, are for a Sunbeam Mixmaster Model 12...uselful for a Dormeyer only in the most general of terms.
Dec 12, 2011 | Food Mixers
does the Freerider kensington have oil in the drive motor? if so how do I check it and what type and quanity does is it use? Also does anyone have a workshop manual for this
No Oil but you do have a grease nibble located on top of the gearbox, get hold of a grease gun and give it three squits of grease.
Regards
GeWiz.
Mar 15, 2009 | Health & Beauty
156 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
