Tip & How-To about Vehicle Parts & Accessories
How to repair a broken door handle on a 1997 Buick Park Avenue.
You can find videos about removing the door panel and the exterior door handle on YouTube, so I will not cover those in this post. Other posts about this repair involve things like drilling a hole and inserting a bolt into the broken plastic handle, but if the breakage is in the area where these photos show, those fixes can fail in time. This fix reinforces and improves the faulty design of the part; in other words, auto makers (including BMW!) use plastics where metal, such as light-weight aluminum, should have been used. INSTRUCTIONS: 1. Remove the interior door panel. 2. Peel back the plastic covering from the door to access the door's interior cavity. 3. Remove the 2 10mm bolts on either side of the handle securing the door handle to the body. I recommend a ratchet wrench for the easier-to-reach nut and a socket for the other. 4. From the outside, pull the door handle out enough to reach the lock and opener rods from the plastic connectors on the handle so you can remove the handle from the door. 5. Remove the metal door opener arm from the handle. One bolt holds it in place. 6. Fashion a "splint" from a 1" X 1" piece of aluminum. It should be thin enough (about 2 or 3 millimeters thick) to wrap around the broken handle arm as shown in the attached photos. Be CAREFUL not to damage the other plastic handle components. In my photos, it appears a previous owner tried to repair the breakage with a thin bolt. You can see the dried, cloudy-colored glue beneath my aluminum splint. Be sure your splint is wrapped tightly around the broken arm so that the arm cannot come apart again. Good pliers are essential here to bend the aluminum splint as shown. 7. Once completed, reattach the metal opener arm to the handle and ensure the spring end rests in the notch of the arm. 8. Reattach the handle to the door body, ensuring the rods are back in their proper plastic "hooks". You cannot attach them incorrectly, as they only fit one way. Removing and reattaching the screws inside the door cavity can be tricky. The door frame edges are sharp. Be patient and careful not to cut yourself. It will probably take a good five minutes or more to get the screws back in place and tightened.
Vehicle Parts & Accessories Logo
Remove rear passenger door panel Mercedes ML350, 2005
Open crank window.
Remove cover for door handle and unscrew 2 screws.
Unclip SRS panel and unscrew screw.
Press door liner off bottom, fron and rear inner door panel with wedge.
Lift door liner up and out.
Unhook inner door actuator.
Unclip inner lock on door liner.
Remove lamp.
Sep 24, 2013 | Mercedes M-class Ml Ml350 Ml500 Ml55...
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
I need instructions, written and hopefully with photo examples, that will teach me how to replace the passenger side mirror on my Ford Sport Trac. The truck is a 2004 model and the mirror is motorized with no heater. Does anyone know if there is a video posted somewhere?
Removal and Installation
NOTE: LH door is shown, RH door is similar.
  1. Disconnect the battery. For additional information, refer to Section 414-01.
  1. Remove the front door window control switch panel and trim covers.
    1. Remove the door screw cover.
    1. If equipped with power windows, remove the door window control switch and disconnect the electrical connectors.
    1. Remove the door handle bezel
3. Remove the door handle screws
  1. If not equipped with power windows, remove the screw and the window regulator handle.
  1. Remove the screws and the front door trim panel.
ganyapr_4.jpg6. Remove the door speaker Remove the screws.
Disconnect the electrical connector.
Remove the door speaker.
7. Disconnect the exterior rear view mirror electrical connector
8. Remove the nuts and the exterior rear view mirror.
Feed the power mirror wiring through the opening in the front door.
9. To install, reverse the removal procedure
i hope that this could help you
2010&c18=modelyear&c20=n712771&c35=wsm%2cfront%20door%20trim%20panel%2cs5r%2c501-05%2cremoval%20and%20installation&s=1280x800&c=32&j=1.3&v=y&k=y&bw=931&bh=469&ct=lan&hp=n&[aqe]
Feb 20, 2011 | Ford Explorer Sport Trac Cars & Trucks
1,189 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
