Tip & How-To about Android Apps
12 Most Essential Tips To Save, Improve & Extend Battery Life
Have you ever faced the situation where you are in hurry and suddenly your battery goes down? I think everybody have gone through such a kind of situation. So it's the time to think on what can you do to not to stuck in such a situations? How to get rid of this problem? How to increase the performance of your gadget battery? Learn how to extend and improve the battery life.
In last posts under the topics of Android, we have seen how to track lost mobile phone and how to solve display flickering error, but today we are going to focus on battery issues, because as long as our device is running smoothly we are gonna work smoothly. Not only proper charging is essential for preserving the health of battery but taking care of battery does more work to save it much longer than we thought. As we know, today we have devices which are comes with Li-ion and lithium polymer batteries but as time goes these rechargeable batteries loses their capacity.
Here we goes, we've got the ultimate guide on how to extend and improve battery life. Try these tips to extend your battery capacity. See what's sucking the most juice. And try to get out of battery problems. Not only tips but also we are here to provide you the instruction to change the settings for improving battery life.
Just follow these tips as shown below...
1. Proper charging:
First and most important thing, try to avoid using your device till the battery falls down below 10% and prevent it to go fully discharge.
2. Change the screen brightness:
Brightness of the screen is the next most affecting factor for battery drain. As long as the screen is ON and with higher brightness; the faster your battery goes down. So change the screen brightness as low as you can stand it and still read a text. Moreover set the locking period as quick as possible. As quick as it gets shut down, the more power you save.
3. Avoid over charging of phone when it got fully charged:
First don't use phone while charging and don't keep your device charging once it got fully charged. Moreover don't forget to plug-in your device to charge, when the battery falls bellow10%.
Read More: http://www.problogbooster.com/2015/07/most-essential-tips-to-save-improve-extend-battery-life.html
Reff.:
12 Most Essential Tips To Save Improve Extend Battery Life
Android Apps Logo
Suddenly, my automatic door unlock button on remote for my 2005 Chevrolet Equinox will not unlock doors and alarms goes off if I manually open driver's door and don't start car right away. Wh
I tried replacing battery in my remote. Sometimes it work and sometimes it doesn't. I think it could be a wiring problem in the remote. I know it's a major paun having to hurry up and put key in ignition befofr alarm starts going off.
Oct 30, 2012 | 2005 Chevrolet Equinox
I have a 1991 chevy blazer S10 4x4 was driving on the highway and very bad shaking happend then slowed down for awile.. shaking went away but comes and goes! notice trans fluied coming from both ends of small drive shaft could sum kind of bearing be gone...don't know need help to solve problem!!
You stop using the vehicle NOW
COMMON SENSE
It will have to go to a repair shop
I would suggest a local trans shop, first
It could be a leaking seal,but one trip
down the street, and you could destroy
the drivetrain in a hurry, if your fluids are gone
Apr 26, 2011 | 1991 Chevrolet S-10 Blazer
suddenly the screen of my n72 mobile has gone blank.only light is on . no displays.please help
Hi Friend,
Wither you have done any software installation in your mobile,Check it has been properly installed or not.After you have checked again you are facing this same problem,then kindly do hard reset.For the hard reset kindly follows these steps,
1.Switch off your mobile
2.Remove the sim card,battery and the memory card.
3.Hold the switch on/off button for 20 to 30 secs
4.Now replace the sim and the battery alone,and switch on the Mobile
5.Let it get on after the mobile is on,after its getting settle down now insert the memory card
Check and revert back
Thanks for using Fixya
Regards,
Ayyasam
Jul 12, 2009 | Nokia N72 Cellular Phone
Hibernation
Try holding the power button down for about 30 sec. then see if it will start.
If not remove the battery and the mains power (the power adapter) and wait about 5 min. then try starting.
Nov 21, 2007 | Toshiba Tecra 8100 Notebook
925 people viewed this tip
Top Apps Experts
Are you an App Expert? Answer questions, earn points and help others
