Tip & How-To about Samsung LA32A450 32 in. HD-Ready LCD TV
SERVCIE MODE
Panel Check
You have to check Panel Maker Because of different adjustments as follows. First of all, Check the label rating!
1) Label Rating File
- LCD PANEL MARK
A:ACER(AUO) S : SEC C : CMO
* If not printed you could consider S(sec) panel mark.
Method of Color Calibration (AV)
1) Apply the NTSC Lattice (N0. 3) pattern signal to the AV IN 1 port
2) Press the Source key to switch to "AV1" mode
3) Enter Service mode
4) Select the "Calibration" menu
5) Select the "AV Calibration" menu.
6) In "AV Calibration Off" status, press the " RIGHT ARROW" key to perform Calibration.
7) When Calibration is complete, it returns to the high-level menu.
8) You can see the change of the "AV Calibration" status from Failure to Success.
Method of Color Calibration (Component)
1) Apply the 720p Lattice (N0. 6) pattern signal to the Component IN 1 port
2) Press the Source key to switch to "Component1" mode
5) Select the "Comp Calibration" menu.
6) In "Comp Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "Comp Calibration" status from Failure to Success.
Method of Color Calibration (PC)
1) Apply the VESA XGA Lattice (N0. 21) pattern signal to the PC IN port
2) Press the Source key to switch to "PC" mode
5) Select the "PC Calibration" menu.
6) In "PC Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "PC Calibration" status from Failure to Success.
Method of Color Calibration (HDMI)
1) Apply the 720p Lattice (N0. 6) pattern signal to the HDMI1/DVI IN port
2) Press the Source key to switch to "HDMI1" mode
5) Select the "HDMI Calibration" menu.
6) In "HDMI Calibration Off" status, press the "RIGHT ARROW" key to perform Calibration.
8) You can see the change of the "HDMI Calibration" status from Failure to Success.
FOR MORE DETAILS CHE THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB FIND MODELS OR USE DROP DOWN MENU
Samsung LA32A450 32 in. HD-Ready LCD TV Logo
Where can I find the 1/2 inch wide labeling tapes used in Scotch brand (model EA-450) label maker? Label maker is over 20 years Old.
I have found these at Staples and Office Depot, probably other places have them or if you just want them sent to you check Amazon.
Jul 24, 2014 | Office Equipment & Supplies
z4m printer error condition paper out labels will just keep feeding through ?
Sounds like a miss-match on the labels you are loading and the labels it is set up for. You'll have to go into the printer properties and check (and adjust as needed) the label stock selected to make sure they match. Next check the setting on the printer its self for the same for label stock selected. Most likely you're trying to use a label stock different then it was using before.
Jul 16, 2014 | Zebra Z4Mplus Label Printer
Can someone please recommend a personal label maker?
Try the Brother Personal Electronic Handheld Labeler. It is the highest rated labeler on Amazon.
http://www.amazon.com/Brother-Personal-Electronic-Handheld-Metallic/dp/B004H1S6FY/ref=sr_1_1?s=office-products&ie=UTF8&qid=1361353584&sr=1-1&keywords=PERSONAL+LABEL+MAKER
Feb 20, 2013 | Office Equipment & Supplies
Lable feed not working
- check that i the driver taht you have selected detection transmissive.
- Check in the diag menu >sensor adjustement that there is 2 v difference bewteen the backing and when you are on a label if not the case place the backing under the sensor and press feed 5 seconds (you should have transmiise 4,2 V approx. Check that when you put a label the voltage drops to 0 or is down by 2 volts.
Oct 09, 2012 | Toshiba TEC B-SX4 Thermal Label Printer
1,938 people viewed this tip
Jerry Greenberg
Jerry Greenberg
