Tip & How-To about Miscellaneous
Mobile slowing down
Every mobile has it's own memory capabilities. Do not load to many unnecessary applications if you need them. It will slow down your mobile phone. It's better to back up every important documents from the mobile phone , including contacts . I often keep a print out of all the numbers. In case your mobile slows down and you feel that you don't understand the reason. The quick and best way to get back to it's optimal service by the factory reset option. It works like a charm and fixes maximum number of problems in seconds.
Miscellaneous Logo
my mobile slow
To speeding up your mobile follow this,first do not store files or data in Phone memory.Do not install application in phone memory.Do not install anti-virus in you phone because anti-virus occupied plenty of size (eat up all the memory).Immediately delete all the Cach/history etc just after finished using internet.Do not mass memory size of more than 1 GB if possible.There are many related thing to slow down the mobile but if you avoid the following it will be better.Thanks for visiting fixya
Mar 19, 2012 | Nokia 5233 Cell Phone
all application slow
It could be the reason of heavy software installed in your cell phone. Either delete some unnecessary software or install a software called "Memory UP". You can download it from here
http://download.cnet.com/MemoryUp-Personal-J2ME-Edition/3000-2094_4-10895035.html
Scan/Boost your memory from this and it will solve the issue.
best of luck!
Mar 01, 2012 | Samsung Cell Phones
memory low error. i can't receive or send text messages. when i showed it to a friend there are no virus it seems that my phone memory has a lot of saved datas
yes, it is the reason. Free some memory by deleting the unnecessary or less necessary item to get rid form this issue.
Your can download a software Called MEMORY UP from this link. It will help you to free some memory and will speed up your phone. But keep the 1st phase of my solution in your mind. Its mandatory.
download the software from here,
http://www.nokiasymbianthemes.com/free-mobile-applications/memory-up-mobile-ram-booster-nokia-free-download-2
best of luck!
Feb 19, 2012 | Nokia N73 Cellular Phone
very slow functioning of n72
You should format your cellphone
Try not to install unnecessary applications, and dont over load your memory card, it causes hanging problem
May 11, 2009 | Nokia N72 Cellular Phone
Nokia N95 Orange Too Slow.
hi.. the reason for ur slow operation of ur mobile might be due to some software problem...The only way to get rid of this problem is that to format ur entire mobile...Or the other one may be due to full use of ur memory card...I mean for example if u are using 1 gb memory card u are not suppose to fill ur mobile completely for 1 gb.. try to some keep some memory space which will ease ur mobile opeartion...
thank u
Feb 01, 2009 | Nokia N95 Cellular Phone
107 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
