Tip & How-To about Apple OS X 10.8 Mountain Lion
How to change where screenshots are saved on Mac?
Step 1: Search for Terminal in Spotlight Search in the top-right menu bar.
Terminal App
Step 2: Open Terminal and type the following command: defaults write com.apple.screencapture location ~/Documents/Screenshots
Step 3: To apply the changes, enter the following command: killall SystemUIServer
That's it. If you entered the commands successfully, your screenshots will now save to a Screenshots folder within your Documents. Make sure to actually create the folder before applying the changes through Terminal though. Also, you can type any directory that you wish to save screenshots to, as it doesn't have to be ~/Documents/Screenshots if you would prefer something else.
Apple OS X 10.8 Mountain Lion Logo
Wireless Optical Mouse Mi-4150K doesn't connect to pc
windows 7/vista :
-step 1 :Press the windows button (start button).
-step 2 : In the search bar type device manager.
-step 3 : Open the device manager.
windows xp/2000 :
-option 1 for opening the device manager :
-step 1 : Press the windows button (start button).
-step 2 : Open the control panel.
-step 3 : Open the "System properties".
-step 4 : Click on the hardware tab.
-step 5 : Click device manager.
-Option 2 for opening the device manager :
-step 1 : Press the windows button (start button). -step 2 : Select "Run"
-step 3 : Type the following into the text box "devmgmt.msc"
-using the device manager :
-step 1 : Once the device manager is open, click on "Mice and other pointing devices" or "other devices" (if prompt).
-step 2 : In the newly open menu, if there is a "?"right click on it and press update driver.
This should almost force the computer to recognize the hardware plugged into the USB port.
Hope this helped!
Nov 06, 2013 | Trust Wireless Optical Mouse Mi-4150K
890 people viewed this tip
Top Apple Computers & Internet Experts
paulcarew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
