Tip & How-To about Miscellaneous
How to use scaner, camera, printer (any USB device) remotely
We use USB devices every day: MDF's, scanners, webcams, printers, etc. Not all devices you usually use at home can be redirected over the network to other work places. Sometimes your family members may need to use these devices on different computers. Of course, carrying devices back and forth the house is not the best solution:)
You can avoid this headache if you have apropriate software solution on hand. USB Network Gate, one of such software solutions.
USB Network Gate is an essential USB sharing solution that allows sharing USB devices over network or Internet. In other words, Network USB Gate allows using USB devices on a remote computers or virtual machines as if they were connected to it directly. You can also share USB devices over RDP.
USB Network Gate offers much more options and possibilities. Navigate to this website for details USB NETWORK GATE
Miscellaneous Logo
USB device not compatible but nothing in port
Either's there's dust causing a shortcircuit in the mainboard or the front connectors, or one of your usb devices is malfunctioning(the mouse, webcam, printer, usbstick etc )
Nov 08, 2011 | HP Photosmart Premium C309A All-In-One...
F4U017 Belkin 7 port USB hub. No matter what i do, i cannot get this hub to work, i'm running windows 7 ultimate Home, i've updated and updated, it has got something to do with the 'Bluetooth device drivers i think Please help
Rimshot64, you did help someone out here. Two years later, even. And you succeeded where Microsoft "Help," per its tradition, failed. Thank you -- I got my scanner and printer, etc., back, and wasted only half a day uninstalling Microsoft updates (their suggestion).
Aug 02, 2011 | Belkin (F5U237) 7-Port USB Hub
HP Photosmart C6280 not visible as printeroption though installed
this will usually happen if you're disconnecting the USB cable from the computer and putting it back on a different USB ports. try to connect it to where it was working before. this is also true for other USB devices such as scanners and webcams
Mar 13, 2010 | HP Photosmart C6280 Printer
Canon FB630u problem
I have struggled with this same issue for ages, I just found a fix from the HP site for the same problem with an HP scanner - it worked for my Canon LiDE70. Run regedit then:
  1. Double-click HKEY_LOCAL_MACHINE to open the folder in the left pane of the window.
  2. Double-click SYSTEM , CurrentControlSet , Control and then Class .
  3. Select {6BDD1FC6-810F-11D0-BEC7-08002BE2092F} and check in the pane on the right for the Lower Filters string value.
  4. Right-click Lower Filters and delete it.
  5. Disconnect the scanning device and restart the computer.
  6. Reconnect the scanning device after the computer is restarted.
  7. BINGO! it worked!
Feb 13, 2008 | Canon CanoScan FB630U Flatbed Scanner
112 people viewed this tip
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
steve cannon
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
