Tip & How-To about Miscellaneous
TOP TIPS FOR HAIR CARE
Ost people think about preventing hair loss only after they have lost a lot of it. But if you start early (like when you still have a head full of hair) it works out a lot easier both emotionally and financially. In fact, the truth is - preventing hair loss is a simpler process than treating hair loss. Plainly put, it all boils down to some sensible hair care - if you take care to keep the hair you've got, you will be blessed with better looks and healthier hair. So here are a few things you can do to prevent your hair from falling:
1. Follow a healthy lifestyle,
2. Take care of your hair,
3. Avoid things bad for your hair, and
4. Adopt simple Home treatments.
1. Follow a Healthy Lifestyle
Hair, like your skin and your nail, is often a barometer of general health. If you are healthy, your hair will probably look good. And if your hair is falling, it could be a sign of possible health problems.
So everything you do for good health also applies to hair: eat your fruits and vegetables (Vitamin B, Iron, Calcium and Zinc have especially been linked to healthy hair); always consume a protein-rich diet (hair is made of proteins), and drink adequate water.
Dirty hair is more likely to get infected and more likely to fall - so keep your hair clean. Buy good-quality shampoo and hair products (in the long run this is cheaper than treating hair that is already half gone). When you shampoo your hair, concentrate on the scalp and hair roots. When applying a conditioner or hair lotion, it is better to concentrate on the ends of your hair (which tend to dry out faster and are more vulnerable to the damage that comes from exposure).
Trimming you mane regularly helps your hair look and feel better. Besides, it's also a long "bye-bye" to those annoying split ends!
How to Prevent Hair Fall - Slideshow Quiz On Hair Loss
3. Avoid things that are bad for your hair
This seems so obvious it should not need telling. But it apparently does need to be told again because many of us unknowingly adopt several unhealthy hair-practices:
Wearing styles that pull the hair tight (usually into braids or pony tails). Many women pull their hair so tight it actually comes out of its roots. If you change your hairstyle soon enough, your hair will recover. Otherwise, your hair might permanently stop growing from the areas it is pulled most from.
Any chemical treatments (even so-called 'herbal' ones) designed to drastically change the way your hair looks (styling, perming, straightening, hot-oil treatments, hot ironing).
Blow-drying your hair - this dries out the scalp and damages hair follicles. Allow your hair to air dry at least part of the time, or change the heat setting on your blower to the lowest.
Combing your hair or rough toweling when its wet - this will put out some hair strands from the roots and stretch and break others
Even the habit of pulling out hair might do more harm than you realize (some people actually go bald from this).
The idea is to be gentle with your hair. Do nothing that might harm your hair in any way.
4. Home treatments for healthy hair
Here we've mentioned a few home treatments that generations of Indian women have relied on. Give these ancient secrets a shot yourselves!
Make a paste of henna, curd, soaked and ground fenugreek, ground hibiscus flowers, ground gooseberries, and egg (all of them or any one) and apply it onto the hair and scalp for about an hour before shampooing. Done regularly, this will make your hair stronger and better-looking. But remember that henna is suitable only for dark colored hair because it tints hair red.
Wash the hair out with decoction of tea or a bit of lemon squeezed into the water in which you will bathe. (for dandruff).
Apply coconut or almond oil. If doing this daily does not appeal to you, apply the oil on the scalp overnight before shampooing, or apply a drop to the top of your head before you comb out your hair.
Never ever take your hair for granted. The adage "Prevention is better than cure" fully applies to your hair too. Remember, you will sorely miss those beautiful tresses if you let them go away!
Miscellaneous Logo
Best home remedy for Dandruff
no home remedy get head and shoulders , it is the best , does not work the first time but does work , I had it for a long time and this is the only thing I found to work ,
Apr 21, 2015 | Health & Beauty
What are the effective balding treatments available that can work out as a permanent solution?
If you're looking for hair loss remedies, you landed on the right article. We spoke to the experts to get the absolute best way to prevent hair loss.
Here's a breakdown of what we'll address:
1. Nutrition
2. Shampoo
3. Laser Light Therapy
4. Hair Replacement Surgery
5. Propecia
6. Minoxidil
PRP Hair Loss Treatment
Oct 31, 2013 | Health & Beauty
Can excess hair loss lead to baldness, if so what are the treatments available?
Lack of hair growth with specific pattern and areas are generally called as baldness. Excess hair loss is one reason of baldness although genetic as well as hereditary reasons are the main causes of baldness. Treatments of baldness include natural hair restoration, hair transplantation surgery, hair loss treatments etc. My bother consulted a hair transplant clinic in Toronto where he got quality treatment for baldness.
Aug 22, 2013 | Hairart Health & Beauty
What is a receding hairline?
Receding hairline is a type of progressive hair loss mainly experienced by men and some women where your hairline will begin to thin commonly on either sides of your forehead before you get a bald patch on top of your head. It is one of the classes of hair loss in men, a condition popularly known as androgenic alopecia or male baldness patterns. It is characterized by a widow's peak where your front forehead forms a V shape pattern.
PRP Hair Loss Treatment For Early Hair Loss Problem.
Nov 23, 2010 | Health & Beauty
176 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
