Tip & How-To about Cell Phones
LG E612 Hard Reset Google Lock
With article and troubleshooting guide solution for LG E612 Hard Reset Google Lock
  • Method (1): Backup PIN & Google Account.
  • On the pattern locked screen, click on the "forgot pattern" button .
  • You will be asked to enter Backup PIN & Gmail ID & password that was being used in the phone
  • Phone will be unlocked once you have provided Backup PIN ,Google account ID and correct password.
  • Note: No user data will be erased in while resetting pattern with above method
  • Method (2) : Pattern unlock with hard reset.
  • If you do not remember Backup PIN or the Gmail ID & Password details or you has not logged in with his Gmail ID then you should perform hard reset.
  • Note:This method will erase all user data and settings from the phone. and process is irreversible.
  • Make sure phone is Powered Off.
  • Press & Hold the "Volume Down Key (V-)" and "Power button" altogether
  • As LED at the bottom of the phone lights up, Release both pressed keys (V- and Power key)
  • Just after releasing the keys, press & hold "Home" key for about two seconds.
  • The phone will turn ON & perform Factory Reset immediately.
  • Warning!During working on this trick if accidentally your handset may have dead or faulted. We are not responsible for that please read our privacy policy.
Phonetolls
Cell Phones Logo
I locked my cell phone and forget my pattern and nothing seems to have helped
This may depending on your Android version; I'd suggest trying the following ...
OPTION 1
If you fail to unlock with pattern 5 times, you may be prompted for a backup PIN (hopefully you know that) or a "Forgot Pattern" button will appear. The forgot pattern button will ask for your google email & password; follow the prompts to gain access to your phone & create a new pattern.
OPTION 2
If you have a custom recovery installed or USB debugging enabled, there are instructions here: Android Guide Hacking And Bypassing Android Password Pattern Face PI
OPTION 3
Failing the above, you may have to do a factory reset. You'll lose any data/apps/accounts on your phone, but at least you can use it again. This method is detailed in method 2 here: How to Reset Your Android Phone
Sep 27, 2014 | Android Cell Phones
wanting to unlock screen password
2 ways factory reset and remember the password. There are 3 ways to reset it but only 2 are accessible. There is a way to bypass the password lock but only if the phone was put into USB debugging mode before lost password. If this is so let me know I will step by step that method.K
May 23, 2014 | LG Optimus E612 White Android OS Unlocked...
forgot my samsung i9300 phone lock
OPTION 1
OPTION 2
OPTION 3
Oct 11, 2013 | Samsung Galaxy YP-G70CWY 8 GB White Flash...
LG E612 PATREN LOCK
You can reset patter lock if you remember Backup PIN and Google account account ID and password, without loosing your data other wise hard reset is only option but all user data will be erased.
both methods are explained here
LG E612 (Optimus L5) pattern unlock
Aug 18, 2013 | LG Optimus E612 White Android OS Unlocked...
726 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
