Tip & How-To about Healer 4.0 Universal Speedometer Fix Honda CBR1000RR 08-09
HOW TO FIX SPEEDOMETER
YOU JUST CHECK THE WIERRING ,IT MUST THE PLUGH INSIDE THE HEADLIGHT WHICH IS REMOVE FOM THE SOCKET... JUST ATTACH AND ENJOY DONT FORGET TO
Healer 4.0 Universal Speedometer Fix Honda CBR1000RR 08-09 Logo
2001 chev cavlier
I actually just did this a couple days ago, this takes about 20 minutes and a little bit of patience. When you pop your hood you will see a protective piece of plastic over the headlights/radiator, you firstly have to remove the plastic clips holding that piece then pull that piece of plastic off, once done u will see 2 bolts holding each headlight in place, i believe it is a 9/16 socket but if not just find the one that fits, remove the 4 bolts (2 for each headlight) and pull the headlight in an up and outwards manor. if you feel any resistance do not yank look at why it is catching and clear it, then it should just pop out (the headlight and the corner piece and clipped together so dont pull it too far out) then when the bulb is accessible pull the old bulb, put the new bulb in and voila place the headlight back into position, redo the 4 bolts holding the headlights and re-attach the plastic headlight/radiator cover. Enjoy the new lights
Oct 26, 2012 | Cars & Trucks
speedometer just stopped working wondering if theirs a fuse of some sort
YOU JUST CHECK THE WIERRING ,IT MUST THE PLUGH INSIDE THE HEADLIGHT WHICH IS REMOVE FOM THE SOCKET... JUST ATTACH AND ENJOY DONT FORGET TO VOTE ME PLS
May 03, 2011 | 2003 Harley Davidson XL 1200 C Sportster...
my kia rondo, driving ligths dont work , i have brigths, dimms, did check all fuses inside and engine
ur head lights are blown out but ur brights will still be good for a min but ya need to replace head lights positive
Jan 14, 2010 | 2007 Kia Rondo LX V6
How do you change the headlight for a 2001 chevy cavalier
i actually just did this a couple days ago, this takes about 20 minutes and a little bit of patience. When you pop your hood you will see a protective piece of plastic over the headlights/radiator, you firstly have to remove the plastic clips holding that piece then pull that piece of plastic off, once done u will see 2 bolts holding each headlight in place, i believe it is a 9/16 socket but if not just find the one that fits, remove the 4 bolts (2 for each headlight) and pull the headlight in an up and outwards manor. if you feel any resistance do not yank look at why it is catching and clear it, then it should just pop out (the headlight and the corner piece and clipped together so dont pull it too far out) then when the bulb is accessible pull the old bulb, put the new bulb in and voila place the headlight back into position, redo the 4 bolts holding the headlights and re-attach the plastic headlight/radiator cover. Enjoy the new lights
Dec 21, 2008 | 2001 Chevrolet Cavalier
397 people viewed this tip
Top Speedo Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Speedo Vehicle Part and Accessory Expert? Answer questions, earn points and help others
