Tip & How-To about Audi a6 quattro handbrake warning light handbrake hand brake lever
HOE TO SWITCH OFF THE HANDBRAKE LIGHT
HI
IT SI THE SIMPLE PROBLEM YOU CAN HANDLE THIS YOU JUST CHECK THE WIRRINF INSIDE THE HANDBRAKE IT MUST NOT IN THE POSITION JUST CHECK THIS OR LUBE THE HANDBRAKE PART WITH SPRAY IF THERE IS PROBLEM IN THE HANDBRAKE LIKE JAMMED IT WILL RELAESE AND ENJOY THE RIDE
Audi a6 quattro handbrake warning light handbrake hand brake lever Logo
On my 2005 Renault Laguna, the electronic handbrake works fine but warning light is on even when handbrake is released, any ideas.
HI
Jun 22, 2015 | Cars & Trucks
Handbrake Adjustment
site for handbrake adjustment
www.fancyacar.co.uk/car-maintenance/handbrake-adjustment/
goodluck!!!
Jul 25, 2008 | 2003 Toyota Camry
how do I unstick the button on the handbrake of my vr commodore
some times the release button gets stuck in the handle, you may need to pull it apart or lube it. Does the spring feel broken? "I had a problem with the button sticking in a VR. I sprayed some silicon lube in the gap around the button, levered it back out with a screw driver and it never stuck again." last comment > http://forums.mightycarmods.com/showthread.php?3116-handbrake-wont-engage
Oct 11, 2014 | Cars & Trucks
my handbrake light keeps flickering on my 1996 vw golf convertible
this could simply be a loose connection on the handbrake switch but this light is also the brake fluid level warning light so it might be a good idea to check the brake fluid level too. also it might be part of the brake pad warning system ane may indicate that the brake pads are nearing replacement it is also required to replace the warning wires with the pads
let me know if this helps
cheers mike
Aug 02, 2012 | Cars & Trucks
volvo s40
The handbrake adjuster is under the centre console behind the lever. If its coming too high, check that the levers at the rear brake calipers are free and moving back to their stop position - they are prone to seizing up on older or little used cars. They can usually be freed off with a bit of lube and working the lever back and forwards. If that dosn't work, unfortunately you'll need new calipers. Do not adjust the handbrake cable unless the caliper levers are at their stops as this seriously reduces handbrake efficiency!
Jan 08, 2009 | 2000 Volvo S40
284 people viewed this tip
Top Audi Cycling Experts
John Egan
John Egan
Are you an Audi Cycling Expert? Answer questions, earn points and help others
