Tip & How-To about Vehicle Parts & Accessories
How to use car rim paint?
1. Clean the hub with Latop Wheel Cleaner.
2. Cover the air ****, brake and the tire.
3. Shake the can before spraying, but avoid shaking during the spraying process. Keep 10-15 cm of distance.
4. Spray rubberized paint for the second time after 5 minutes. You are suggested to spray for 4-5 layers. Move the shade and you've finished it. Rubber Paint Spray Peelable Multi purpose Custom Rim Paint
Vehicle Parts & Accessories Logo
shaking at low speed
Does it shake all the time, or only when you use the brakes ?
A slow speed shake without using the brakes is most often a bad tire. The alignment only affects how the car steers.
Jul 26, 2013 | 2002 Dodge Stratus
Where the hell can I get a FREE PDF download for my Ford fusion 2 for the removal and replacement of the rear wheel bearings as well as the torque settings for the final nut after replacement.All the so called Free sites are nothing but a con. Ford Fusion 2 2005 reg /non non ABS
Rear Suspension - Rear Wheel Bearing Fusion 2002.75 (06/2002-)
-Removal and Installation
Special Tool(s)
Installer, Differential Bearing
205-062
Installer, Input Shaft Seal
307-210 (17-041)
General Equipment
Soft faced hammerWooden block
Removal
CAUTION: The brake drum and hub assembly removal in this procedure is for installing a new wheel bearing, not for access to brake system components.
-All vehicles
Remove the dust cap.
Remove the wheel and tire.
For additional information, refer to: Wheel and Tire (204-04 Wheels and Tires, Removal and Installation).
-Vehicles with rear drum brakes
Release the parking brake.
Remove the brake drum and hub assembly.
Remove and discard the wheel hub retaining nut.
-Vehicles with rear disc brakes
Remove the brake disc.
For additional information, refer to in this section.
Remove the wheel hub.
-All vehicles
Remove and discard the wheel speed sensor ring (brake disc shown).
Remove the circlip (brake disc shown).
Using the special tool, remove and discard the wheel bearing (brake disc shown).
-Installation
-All vehicles
CAUTION: Support the wheel hub assembly on the wheel mounting face and not on the wheel nut studs.
Using the special tool, install the new wheel bearing (brake disc shown).
Install the circlip (brake disc shown).
CAUTIONS:
Make sure the wheel speed sensor ring is not knocked, damaged and kept free from metal fragments.
Protect the face of the wheel speed sensor ring with a non-ferrous flat block to prevent damage.
Make sure the wheel hub or brake drum is adequately supported and do not allow it to rest on the wheel studs..
Make sure the wheel speed sensor ring is pressed on slowly and squarely until fully seated.
Do not exceed a maximum load of 10 kN.
Using the special tool, install a new wheel speed sensor ring (brake disc shown).
CAUTIONS:
Avoid impact on the wheel speed sensor ring.
Make sure the wheel speed sensor ring is clean.
Avoid any contact between the wheel speed sensor ring and a magnetic surface.
Rotate the wheel hub assembly 10 times counter-clockwise when tightening the wheel hub retaining nut to prevent damage to the wheel bearing.
NOTE: Install a new wheel hub retaining nut.
Install the brake drum and hub assembly.
Apply the parking brake.
CAUTIONS:
Install the wheel hub retaining nut.
Install the brake disc.
-All vehicles
Install the wheel and tire.
NOTE: If the dust cap is damaged a new dust cap must be installed.
Using a soft faced hammer and a wooden block, install the dust cap.
There is no real torque settings for the rear wheels, except to say, do not over tighten or you will stretch the lugs and the will loosen over time.
May 28, 2011 | Ford Fusion Cars & Trucks
Steering shacks replaced steering damper still shacks
shakes?or shacks?Let's just say that you mean shake.If your brake pedal pulsates,replace the rotors.If your steering wheel shakes(low speed)broken belt in front tire.Jack up one tire enough to clear the ground,spin it.Spins nice,lower and jack up the other.Spin that one,if the belt is broke it'll be very noticable.While up in the air check the lug nuts,if they're loose it can make the steering shake too.If the shake is at highway speed,bad shocks or tie rods or ball joints or a combination of these.Jack up a front tire and try to move it(Key turned off to lock steering).If it moves top to bottom,ball joint.Side to side,tie rod.Doesn't move,shocks.The worst could be a bad hub bearing,but you'd hear it and you said nothing about any noise.
Nov 05, 2009 | Harley Davidson XL 1200 C Sportster Custom...
1,251 people viewed this tip
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
