Tip & How-To about Crafts & Hobbies
Generic, All Around Useful Painting Tips...
When faced with an expensive Paintbrush with dried paint, don't toss it, Save It...
  • Soak it overnight - Starting out with very warm Vinegar.
Now so it doesn't happen again...
  • Clean well, Place it into proper sized Ziplock Bag & then put into a Pringles, or Coffee can, Then cap it with the plastic Lid.
When storing a partially used can of paint, instead of just putting the lid on it,
  • place a sheet of plastic sheeting like Saran Wrap over the top, then press the lid on.
Instead of using the edge of the can to remove excess paint,
  • find a large thick Rubber Band, or Tie a wire or Twine over the top and bottom, exposing it over the middle of the opened can. Now just use that to remove excess paint & it will fall directly into middle of can and keeps can clean.
If your painted project appears a little rough after painting...
  • Don't use sandpaper or steel wool to remove roughness, that will leave scratch marks, even if gone over lightly, instead use Brown Paper Bag.
If going to apply new coat or 1st coat over metal,
  • wipe down really well with Vinegar. This will help keep paint from bubbling, chipping, blistering or peeling away.
To keep paint brush marks from being noticeable, especially on furniture or cabinetry, or Doors,
  • Use a product called Flotrol. This will eliminate streak and brush marks.
And one more tip
When needing to know what type of paint is on your project that you want to repaint...
  • Pour some Vinegar on a cotton ball, then rub on the paint. If cotton ball has paint on it, it is Latex, Not Oil based.
Happy Painting
Crafts & Hobbies Logo
Can't unclog black 3eBK nozzle.
If you said you replaced cartridges with new ones and it still doesn't work, the printer is the issue and may need to be replaced.
Nov 09, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I droped my phone and it got some dents and scratches. How can I fix that or maybe spraypaint it?
You would have to sand down, tape and spray (with a metal paint keep in mind) the whole phone over again otherwise it won't be a smooth finish. You could try some touch up paint and a real steady hand. Cut the tip of a normal kids paintbrush at an angle so it's pointed but still has a bit of surface area. That should help. Remember, if the paint doesn't fill the chips you can always add another coat to fill it in but only after the paint is dry. Good luck I hope it works for you.
PS: There might be a face plate kit for your phone. Post the model if you want me to find out for you.
Jul 09, 2008 | Samsung Cell Phones
canon pixma mp780 printing problem
If deep cleansing via software doesn't work then you've got to manually clean your print head unit. Sometimes you'll have to bite the bullet and get a replacement print-head unit ($$). If you're at the stage that you're considering replacement, then you've got nothing to lose by cleaning the print-head unit yourself. It's simple. Remove all ink cartridges first then remove the print head itself. Place the print head unit in a saucepan of warm (NOT boiling hot) water and leave to soak for an hour. (Protect your clothes - it gets messy) After an hour, flush the printhead unit under a running tap. Don't run the water too fast or you may damage the unit) You should flush until the water runs clear. Do not attempt to clear the nozzles with anything other than water - they are very fine needle jets and you will damage them!! If needs be, return to saucepan and leave to soak in warm water again and repeat process. When you are satisfied that the printhead is clean, you need to dry the unit thoroughly. Shake as much water from it as you can then pat it gently dry. Next place it on some absorbant kitchen paper and put the unit in a warm place to thoroughly dry (Overnight in a warm airing cupboard would be good). Once dry, refit the unit put in (Preferably new - but I've used existing one's without problem) cartridges and run a cleaning cycle. Your printer should now work as if new!!! - In Most cases!! - sometimes though, you'll either have to replace the print head unit - which sometimes can be more expensive that simply replacing the printer. What have you got to lose though eh? CLIVUSS
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
871 people viewed this tip
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
