Tip & How-To about Miscellaneous
How to remove permanent marker
Clothes- Hand Sanitizer
Walls- Toothpaste or hairspray
Wood- Rubbing alcohol
Furniture- Use Milk
White Board- Dry Erase
Miscellaneous Logo
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
A pen exploded in the dryer and I cannot remove the ink from inside the drum.
Hello 5.....
  1. Turn the dryer off and remove any laundry from inside the drum.
  2. Unplug the dryer.
  3. Dampen a paper towel with rubbing alcohol.
  4. Scrub the ink stain with the dampened towel. Repeat, if necessary, with a fresh towel dampened with rubbing alcohol, to remove all the ink.
  5. Wipe the area with a cloth dampened with water, to remove any alcohol residue.
  6. If the stain persists, soak a white rag with rubbing alcohol or hairspray and scrub the stain. It may take repeated applications to dissolve the ink. Joe
Thanks for choosing Fixya!
Mar 08, 2011 | Amana Dryers
liquid spill on keyboard clean how to...will clean water blow out dry work ? cleaning without dis-assembly possible ?
rubbing alcohol or hand sanitizer the alcohol dries fast and it wont hurt anything.. just take a towel and wipe it off.. i rub the sanitizer in my hand so its not running in globs and then rub the keyboard but if you use rubbing alcohol then just use a rag er something.. if its taking to long to air dry towel dry.. Thanks Kevin
Jun 11, 2009 | IBM ThinkPad R52 Notebook
ink in the dryer
Rubbing alcohol will work to remove most of it if you use alot of elbow grease.
What I found worked the best and quickest was a Mr Clean Magic Eraser wetted acetone nail polish remover. Leave the dryer door open to let it air dry, then put a couple of white towels soaked in bleach water and run the dryer on a non-heat cycle to remove any remaining smudges.
To be paranoid, I then ran the same towels through the washer and dryed them on high heat to make sure there was no ink I missed that might ruin any further clothes.
Mar 28, 2008 | Roper REX4634KQ Electric Dryer
79 people viewed this tip
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
