Tip & How-To about Electrical Supplies
How to extend battery life in Ni Cad batteries.
If you still have some of the older Ni Cad battery tools and you are not getting very long life between charges, try this trick. Put your batteries in a bag or container that you can seal, and stick them in your freezer for 3 to 4 days and them pull them out and let them warm up to room temperature before you re-charge them. This is only a short term solution and does not work all of the time but I have seen it successful on many different brands of tools. Hope this helps!
Electrical Supplies Logo
can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
I just bought the Lithium - ion batteries for replacement for my 18.0 volt ni-cad battery. when I put it (ion battery) in the charger (ni-cad charger) no lights come on. what's up?
Lithium Ion batteries don't charge the same way ni-cads or ni-mh do. You need a lithium ion specific charger to charge them. (Some chargers do multiple types.)
Apr 22, 2012 | Ryobi Multi-Volt Battery Charger
ryobi battery will not hold a charge p100 18 volt, bd0737
If the battery has been used a lot or has not been kept charged up it likely is shot. A battery that is not used a lot should be kept charged. I keep my battery operated drill on the charger almost all the time. I have two and change them once every two weeks. Several years old and they both work good.
Oct 08, 2010 | Hand Tools
LCD IS NOT WORKING WHEN CHARGEABLE BATTERIES IS PUT IN THE BP300 GRIP
ni-cad or ni-mh rechargeable batteries all have charging cycle life and will fall in effeciency. in saying that, batteries used for some time will be not be as powerful as the new ones, and over or under charged batteries also wouldn't give you expected power.
i guess the CR123A you replaced is a new one, so it has the desirable voltage and current.
LCD itself and the driver actually do not require a lot of power, but the camera does, which draws away from the battery.
pc-cook
Jan 25, 2008 | Canon EOS Elan 7 35mm SLR Camera
499 people viewed this tip
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
