Tip & How-To about Garden
Less cleaning of undercarriage of lawn mover
Before you start mowing.....turn motor to see undercarriage.....spray with the brand Pam cooking spray (all over)..........(1) cleanup will be LOTS easier; AND, (2) Pam is safe for food.........so safe for your grass...!!
Garden Logo
How to Clear out dish soap from the jet dry resevoir?
Use a shop vac and suck it all out. Then, spray some Pam-type cooking spray grease into the jet dry reservoir and then, A) start a normal wash cycle and stop it a few minutes after it starts the spray action. Then, open the door and look for suds. B) If you see suds, spray them with Pam spray to knock them down and then C) cancel the wash to drain it out. Repeat ABC until all the suds are gone.
Then, whatever you do, DON'T put dish soap in the jet dry reservoir again!
Good luck
Oct 21, 2014 | KitchenAid Dishwashers
my ice maker does not dump ice. What would cause it to not dump?
Hello. Remove the bin from the icemaker, turn off the icemaker by raising the wire. Then use a hair blow dryer to thaw and remove any remaining ice and dry out the ice mold. Once it is dry, spray it with PAM cooking spray to lubricate it again. let the pam dry for a few hours then put the ice cube maker back in operation. J.
Jun 12, 2010 | Estate TS25AFXK Side by Side Refrigerator
I fixed a kink in the water line, water filled the ice maker, cubes froze, but the mechanism that pushes the ice out seems to have gotten stuck after the ice started to push out about 1/2". Any ideas on what could be the issue? Also there's a small white plastic screw on the side that looks like some sort of calibration or adjustement screw, what is this for?
Ok. here is the fix. warm up the frozen cubes with a blow dryer to get them out. Then dry off the area, keep the metal bar up so more water doesnt come in and slow you down. When the ice cube mold is dry spray it with PAM cooking spray, which is a safe lubricant in this application. Let the Pam dry for ten minutes and then turn your lever down. You will have cubes with in 24 hours or less and they will eject as they should.
Jul 07, 2009 | Estate TS22AFXKQ Side by Side Refrigerator
Does anyone know if you can manually lift the driver side window?
Can you hear it at least trying to lift, Motor grunting kind of ? If yes try to spray some (lots of ) silicone spray, or even "pam" cooking spray down along the edges where the felt is to see if that will help loosen it up & lubricate the guides. The odd time a sharp blow to mid area of door inside panel while holding switch in up position, you may get lucky one time.
Dec 13, 2008 | 2004 Jeep Grand Cherokee
599 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
