Tip & How-To about SanDisk Electronics - Others
Backups or transfer usage
Always keep one handy, with as large as you can afford- minimum 8 Gb, greater always good.
Electronics - Others Logo
how can i turn my credit rating around?
Very simple, pay your bills on time, try NOT to get to the point of having credit collectors call you. If you're in debt now, you should always start by paying the smaller of the bills off as fast as you can, get those out of the way then concentrate on the larger bills and always pay more than the minimum or you'll never get out of debt, such as, if your credit card says minimum payment due is $25 pay $50 if you can but pay at least $35, if you can afford to slam a couple of toward it then do it. Don't wait until a day or two or a week after due date, always pay something at least a couple of days before the due date.OH and the biggest thing, STOP charging on your cards and or making loans. Only use your cards when you HAVE TO other than that, pay cash or use your debit card linked directly to your bank. Your credit card usage should never really exceed 30% so get it below that and sign up for creditKarma or something to keep an eye on you credit.
Jun 09, 2017 | Computers & Internet
I'm going to buy a new tv. I already have an Apple tv box. Should I buy a smart tv and eliminate the box or get a regular tv and keep the box
It has always been a good rule of thumb when buying electronic equipment to buy the best you can afford. I would buy the SMART TV and sell the apple box. I remember reading in a 'get rich quick book' that there is always someone worse off than yourself. Believing this then there will always be someone that will buy your good quality second hand gear. Cheers
Feb 10, 2017 | Apple Televison & Video
What is the piston to bore clearance on a 1984 Harley soft tail with wiseco pistons?
Usually the minimum clearance is listed on the outside of the Wiseco box. You can always call them, they are very good about helping folks.
I will say don't use the stock Harley clearance as a guide, the Wiesco's are forged so need greater clearance and would seize at the stock clearance, Frank
Jan 29, 2015 | Harley Davidson Motorcycles
need to upgrade graphics card for dell latitude D800.Also need a bigger hard drive 200 GB or more.Have only 40 GB now with Windows Vista taking up most of it!
In this laptop the video card is a special format one, it can't be replaced with any other one because no other one in the same format was ever made. But you can always put a larger hard disk - as large as you want and you can afford to buy. Just make sure it's a PATA one - like this one.
Oct 05, 2011 | Dell Latitude D800 Notebook
printer won't print
Yes, these machines are designed to only function if all inks are present and meet minimum requirements. Not doing so could result in damage to the print head. The large black ink, the 5, is also a pigment based ink and highly prone to clogging. Letting this machine sit for extended periods of time unused can also cause damage, possibly irreparable, to the print head. We typically recommend people using these style machines always keep a back up set of cartridges on hand to avoid issues.
Mar 23, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
799 people viewed this tip
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
