Tip & How-To about General Electric Electrical Supplies
AFCI-GFCI Circuit Breakers - Your Home’s Electric Service has Never Been Safer
Would you ever consider driving a vehicle without functional brakes? Probably not. Driving such a vehicle is simply too dangerous and yet the majority of Americans do something every day that is potentially more dangerous than driving a car with no brakes. We live with home electrical service that is not nearly as safe as it should be. As a result, thousands are killed or seriously injured by electrical malfunction, electrocution and electrical fires every year. What's even more alarming is that most homeowners are unaware of this sobering fact or assume making their home's electrical service safer is unaffordable. Thankfully a recent breakthrough in residential electrical service technology is making it easier and more affordable than ever for homeowners to protect their families from electrocution, electrical fires and other deadly electrical safety hazards.
The Problem with Your Home's Electrical Service
The majority of homes in the U.S. today are approximately 40 years old and unless they have had their electrical service updated to the latest National Electric Code (NEC), they contain either fuses or traditional circuit breakers in their electrical panels. While fuses and circuit breakers look and function differently, they both serve the same purpose. They interrupt the flow of electricity to a circuit in your home if they sense an overload or electrical short.
For decades fuses and circuit breakers have been the main electrical safety component of most home electrical services. The problem with traditional fuses and circuit breakers that most people are unaware of is that they don't provide protection from some of the most common and most deadly of residential electrical hazards, electrical fires and electrocution.
The National Fire Protection Association (NFPA) reported that in 2011 that nearly 2000 people were killed or injured in home electrical fires alone. This doesn't include the countless others killed or seriously injured as a result of accidental electrocution. What's worse is that most homeowners are unaware that almost all of these deaths and injuries can now be prevented by an inexpensive and revolutionary new type of circuit breaker, known as the AFCI/GFCI or Dual Function circuit breaker.
What are Arc Faults and Ground Faults and why are they so dangerous?
The acronym AFCI stands for Arc Fault Circuit Interrupter and this device is designed to cut the flow of electricity when it senses an arc fault. If you have ever plugged in an extension cord or flipped a light switch and heard a loud popping sound, then you have experienced an arc fault. The sound that you hear is actually electricity jumping from one electrical contact in the plug or switch to another. Though this might seem harmless, an arc fault causes an excessive amount of heat in your home's wiring which, over time, can actually melt the wiring's insulation leaving the wire exposed. This can lead to an electrical fire. Since the majority of your home's wiring is hidden behind its walls, it's almost impossible to know if your home is at risk.
GFCI stands for Ground Fault Circuit Interrupter. Much like an AFCI, a GFCI is designed to cut the flow of electricity to a circuit; however a GFCI is triggered not by an electrical arc, but rather a ground fault. This is when electricity travels outside of its intended path as it tries to find the shortest path to ground. An example of this is when a person with a live electrical wire touches the ground or something resting on the ground that can conduct electricity. The electrical current will travel through the person's body as it seeks the shortest path to ground, electrocuting them in the process. It only takes 1/10 of an amp to kill a human being. To give you an idea of just how little power that is, the average 60 watt household light bulb draws 5 times the power needed to kill a person.
Why are these dual function AFCI/GFCI circuit breakers so important?
Prior to the development to the AFCI/GFCI circuit breaker if the NEC called for a specific area in the home to be AFCI and GFCI protected, typically laundry rooms and kitchens, to have both AFCI protection and GFCI protection electricians had to use a GFCI outlet and an AFCI circuit breaker to meet this requirement. The problem was that this was rather inefficient and troublesome, especially when the circuit was tripped because the homeowner had to check both the outlet and the circuit breaker to see which had tripped and then reset it. Not only does the dual function AFCI/GFCI circuit breaker eliminate this problem, it also provides better protection and can be installed on every circuit in your home quickly and easily for ultimate protection. Residential Electrician
Electrical Supplies Logo
how do I take off thebrakes pressuer switch
Hi Tom:
If you open the hood (bonnet) and look at the brake master cylinder there should be an electrical connection. The thing on the cylinder that the wires connect to will be the switch.
I'd try unpluging it and then use a continuity meter to try to check the switch function.
DEFINITELY replace the switch if it is not functioning correctly.
It would be DANGEROUS to simply dis-connect it and then drive without brake lights.
Aug 06, 2016 | 1993 Toyota Corolla
What does the ESC light on my Hyundai entourage mean? what does the acronym even stand for?
Your owner's manual says = Electronic Stability Control. Optimum driving safety now has a name : ESC, the Electronic Stability Control. ESC recognizes critical driving conditions, such as panic reactions in dangerous situations, and stabilizes the vehicle by wheel-individual braking and engine control intervention with no needfor actuating the brake or the gas pedal. ESC adds a further function known as Active Yaw Control (AYC) to the ABS, TCS, EBD and ESC functions. Whereas the ABS/TCS function controls wheel slip during braking and acceleration and, thus, mainly intervenes in the longitudinal dynamics of the vehicle, active yaw control stabilizes the vehicle about its vertical axis. This is achieved by wheel individual brake intervention and adaptation of the momentary engine torque with no need for any action to be taken by the driver. ESC essentially consists of three assemblies : the sensors, the electronic control unit and the actuators. Of course, the stability control feature works under all driving and operating conditions. Under certain driving conditions, the ABS/TCS function can be activated simultaneously with the ESC function in response to a command by the driver. In the event of a failure of the stability control function, the basic safety function, ABS, is still maintained.
Sep 02, 2011 | 2006 Hyundai Sonata
We are driving down the road and the brake light comes on and then the car stops driving smoothly....and it sounds horrible.
the sound you are hearing is a warning that 1 or more wheel bearings are not working or simply need replaced, please be advised that it is very dangerous to drive a vehicle with a bad wheel bearing as it could cause you to wreck. for more information or help please call 419 689 1114 for futher assistance
Apr 24, 2010 | 2001 Toyota Prius
brakes locked up ran through stop sign 04 santa fe
it sounds to mee like the brake power booster or abs is acting up.if you dont feel safe driving it use it as a trade in for another vehicle that you feel more comfortable with
Jan 27, 2009 | 2007 Hyundai Santa Fe Limited
Right side shakes when appling the brakes
Sounds like the right side rotor is out of round.Either have it machined or replaced. Also when checking the rotor make sure the steering linkage is good at the tierod ends. You should probably have both rotors serviced at the same time
Dec 01, 2008 | 2002 Chrysler Town & Country
823 people viewed this tip
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
