Tip & How-To about VeriFone Retail Supplies
How to unlock the keypad on a VeriFone Terminal
If you are getting a keypad locked message.
from the main screen press the number 8 and then 1 alpha alpha 66831 enter then NO
this will unlock the keypad, which got locked by pressing the number 8.
Retail Supplies Logo
How do I change the auto settlement time on verifone vx 510
Press 6 then set up, enter password- alpha alpha 66831 enter (alpha key above 2 key) then it will display
phone
terminal
communications
Select Terminal using purple more key or the next key if one displays until you see auto settle time. Press Select- then on bottom of screen you can enter the time using HHMM- military time. if you want to close at 1100pm you would enter 2300 press exit and yes to save, red x until back at main screen. if your screen goes to a default screen that says comm serv and something else, choose the option that is not comm serv and this should take you to a home screen you are used to seeing.
Feb 27, 2015 | VeriFone VX510
verifone vx520 tamper please enter pasword
if you have a tamper you may need to get it replaced, try this press enter key and if it takes you to a menu press set up, enter password, do you have the password? 1 alhpa alpha 66831 ( the alpha key is above the 2) then press more until you see date and time, change date and time see if this fixes tamper or press red x until you get antoher screen or press f2/f4 same time enter password and then clock change time if this does not work you need a new terminal
Jul 22, 2014 | VeriFone VX510
how do I unlock vx510?
By unlock is this for the keypad, if so press the number 8 and enter the password of 1 alpha alpha 66831 enter and then NO- this will unlock the keypad, if there is another lock please submit that question
May 12, 2014 | VeriFone VX510
Vx510 terminal says keyboard locked
this happens when the number 8 is pressed. to unlock press 8 enter password 1alpha alpha 66831 enter, then select no, this will unlock your keyboard.
Apr 20, 2014 | VeriFone VX510
I JUST WANT TO CHANGE THE TIME.
PRESS DOWN ARROW KEY ¯ , SELECT OTHER SET UP, PASSWORD? 1 ALPHA ALPHA 66831, PRESS GREEN ENTER KEY, PRESS DOWN ARROW KEY ¯ , SELECT DATE/TIME, KEY IN CURRENT DATE MM/DD/YYYY, PRESS GREEN ENTER KEY, KEY IN CURRENT TIME HH/MM/SS, PRESS GREEN ENTER KEY, PRESS RED CLEAR KEY TO EXIT TO IDLE SCREEN.
Nov 09, 2010 | VeriFone Omni 3700
832 people viewed this tip
Top VeriFone Retail Supplies Experts
Da Doc
Are you a VeriFone Retail Supply Expert? Answer questions, earn points and help others
